Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 55
Thread: Octavia II vRS 4 Motion conversion
  1. #31
    Bowral, NSW
    I've had the rear inside guards foam/metal bracket cut, else it would have shredded tyres, daily, let alone towing.
    I've had VW-Racing springs (Martins old ones) for around 100,000km now, so not adjustable.
    The front doesn't poke much, if at all... but on hard cornering (hill climb - Macquarie Pass ) the fronts will scrub on the top of the wheel arch. No paint damage yet, so fingers crossed!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  2. #32
    Oct 2009
    Mitchelton, Qld
    So with stock suspension will the 18*8 ET45 with 235/40 tyres and towing have issues do you think?
    How much do the VW Racing Springs lower it from stock?
  3. #33
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by donweather View Post
    Some risk of the 235's rubbing the guards during larger suspension travel
    (Lex had this problem but I don't know what wheel offset he was using)
    No problem with 225's
    Not a good option, car can bottom out and have dangerous reactions
    If you want to go lower, do springs and shocks together, $$$
  4. #34
    Oct 2009
    Mitchelton, Qld
    Thanks Martin. I'm not intending to lower the car. Was just interested how much the lowering caused mysticality's rubbing issues over stock.
  5. #35
    Bowral, NSW
    If you're going wider wheels, get the inside metal bracket on the rear guards cut off. Else it *will* shred your tyres.
    Stock 18x7.5 ET51 is not a problem, but x8 ET45 most definitely is. Won't be a problem at stock height on a flat road, but once you get some suspension flex into the mix it'll end in tears.
  6. #36
    Oct 2009
    Mitchelton, Qld
    Hmmm. Sounds like 225s are the way to go then. Thanks.
  7. #37
    Dec 2012
    Yes, stick to 225 - they are already decent sized feet and we know they work well
    You won't see any improved street handling from 235 and are likely to get a bit more noise, plus rubbing issues
    Unless the 235 tyre was cheaper I just wound't bother
  8. #38
    Dec 2012
    Back to the original topic, I have been looking into this
    The Mk1 Octavia was a lot different
    The Mk2 Octavia is a shared platform and the transplant is possible
    I've talked to a few wreckers, I just can't make the numbers work, better to buy a 4WD/AWD
    (Not interested in shipping the gear from Germany)
    For now I'll have to entertain myself replacing LED's in the instrument cluster
  9. #39
    Jun 2012
    What sort of outlay would the parts come too from a local wrecker? I am still pretty keen on this going ahead in the near future.
    I guess finding a frontal damaged Scout that is a write-off would be the preferred route, complete donor to pillage parts from where does one look to purchase written-off cars from apart from classifieds?
    Google here I come...!!!
  10. #40
    Jan 2013
    There is a scout for auction at pickles - written off, believe it's based in Queensland. If you pick it up, pm me! Would like a part or two, not required for your build, off it
    EDIT: Auction is on 21 August 2014 - Online
    07/09, Skoda, Octavia, Wagon - Pickles Auctions Australia
