Results 1 to 6 of 6
Thread: Number Plate LED Fault Code & Traffic Activation
    Jul 2012
    Hi Guys,
    I have tried several LED number plate lights in the MY14 Skoda Octavia.
    No matter what ones get installed, they come up with a "Check Number Plate Light" message.
    When removed and standard filament globes are used, it is back to normal, with no message.
    Is there a way to program VAGCOM to not detect the voltage / current / resistance drop so that it does not come up with the Fault each time?
    Also how does one activate traffic update information?
    I am in Sydney (Bankstown / Hursrtville area) and can travel.
    If you can help, please PM me.
    You need to find some that work with either inbuilt or inline resistors like this:
    Buy Products Online from China Wholesalers at Aliexpress.com
    PM me I can get traffic happening for you.
    Dec 2013
    Narre Warren South, Victoria
    you should be able to set the number plate lights to LED with VCDS, OBD11 can do it as well. I just can't find the adaptations for it.
    found it
    Controller 09 - Central Electronics
    16 - Security Access - enter 31347
    10 - Adaptations
    Number plate LED adaptation (installed std NON canbus down-facing 501’s)
    (1)-Leuchte25KZL HA59-Lasttyp 25 from 18 - 2* 5W to LED Lichtmodul
    2012 MY11 Cappuccino Superb Elegance, TDI. (Gone)
    2014 MY14 Race Blue Octavia Ambition Plus wagon, TSI, Tech Pack. (Wife's)
    2014 MY14 Cappuccino Octavia Elegance hatch, TDI, Sunroof, Tech Pack, Towbar. (Gone)
    2017 MY18 Lava Blue Superb wagon, 162 TSI, Sunroof, Tech Pack, Comfort Pack, Cream Leather, Towbar (Mine)
    Jul 2012
    Does anyone have the cable and software to do the modification to the light setting?
    Dec 2013
    It depends on where you are, there are a few people around with either VCDS or OBD11.
    Sent from my SM-G920I using Tapatalk
    Quote Originally Posted by Smart1 View Post
    found it
    10 - Adaptations
    Also need to set this adaptation channel:
    (6) Leuchte25KZL HA59 - Dimmwert AB 25 - set to 127
    This will set the BCM up in the same way as if it is connected to OEM LED license plate lights. May or may not work for aftermarket units, but worth trying.
