From what I've read the torsen bar setup in the new car is more than fine for the "average" car owner. The new golf too has models using a torsen bar setup.
So I wondered why the base models are so cheap in this version. So cheap that they even udercut the golf in some circumstances. It turns out that all models below 110kw have torsen bar rear suspension instead of the old models independent. This is backwards step in my opinion. But for many its probably not going to be noticed. Only the price will matter to most.
Sent from my GT-I9100
MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
torsion beam. Torsen is a type of slippery diff
I'm not sure why you'd have an issue with it. SOme of the best handling, ex-factory vehicles I've driven had a torsion beam arse-end. Ford Fiesta of around 2005 springs to mind. You can still tweak them a bit too.
Why is there such a discrepancy between onroad costs between the models? It varies between $1300 and $3300. Why does the onroad costs increase by $1000 between the Ambition and Ambition Plus?
Be aware... Rain sensing wipers not in Ambition or Ambition Plus as standard.Looks like auto headlights aren't either if thats what is meant by Light Assist. Not on the option list either, you have to get the tech pack. Have both on my 2010 Scout and I was considering the Ambition Plus before I saw that. Grrrr....
I'm assuming they are quoting NSW onroads so they will bend you over at any opportunity. Stamp duty increases with value. Rego increseases with engine size? & weight? Green slip varies as well?
maybe they are just x-subsidising the price leader to generate showroom traffic.
My11 - Octavia vRS 125TDI DSG Liftback, Anthracite Grey metallic
I went to put an order in for an Ambition Wagon with Travel Pack. None in the country apparently. ETA April to June.
Not to impressed with that to be honest. How could you balls up a release so much?
