Page 320 of 371 FirstFirst ... 220270310318319320321322330370 ... LastLast
Results 3,191 to 3,200 of 3705
Thread: New Octavia ....when? How Much?
  1. #3191
    Jan 2008
    Just put 52.41 litres into the 'about 50 litre' fuel tank, with DTE reading 15km.
    T/C reading was 8.0 l/100 - actual was 8.33.
  2. #3192
    Who is messing with my profile?
    My first tank ran at ~11L/100km. Slow commuting mostly. But G.O.R. in 2 weeks!!
  3. #3193
    Jan 2008
    GOR- awesome!
    Mine included a run to Victor (about 60 kms each way at 80-100 with hills) which it did 7.0 which was pretty good as I was continually using the gears to vary revs and load it up. I've found it best in light traffic runs to work - done a couple in the 6s. Work -home through the hills brings the worst but more fun!
  4. #3194
    Not really had an opportunity to get it on boost for a couple of gear changes yet. Although I did elicit some wicked axle tramp in first. Seems not to cope too well with a boot full in first, better rolling on from second.
    Other thoughts:
    No fuel tank lock or remote release is weird.
    A little less responsive than hoped, maybe it will improve.
    ACC seemed to slip further behind the vehicle I was following, will try again.
    Auto parking was a bit slower a process than just doing it yourself.
    Sound maker sounds crap in Sports mode, better (less obtrusive) in Normal. I'd like to hear and feel the engine itself, no matter how quiet it is.
    Looks tougher than anticipated in blue with black pack.
    Canton not as good as McIntosh of Liberty.
    Kessy - need to read the book to get it to unlock all doors when I'm near, or in the car. Annoying everyone else at present by locking them out.
    Auto tailgate - handy. Nifty that you can set the height it raises to.
    Carpets thin. Suspect they will wear through in drivers footwell before long.
    Door trims a bit cheap too but not where you touch them. However I notice they are marking readily with fingerprints.
    Proper handbrake FTW.
    Steering wheel looks good but leather not as supple as Momo on the Liberty was. And does not go around the full wheel.
    LHS indicator stalk feels unnatural, even though I'm used to it.
    GPS pronunciation is terrible, and being dependent on it in a new city I am learning it takes the shortest route which is invariably the slowest.
    Is there an option to dim/turn off the screen?
    Phone connection excellent and simple.
    Seats comfy but again leather a little less soft than previous ride.
    AC is up to the job.
    Gear shift is nice.
    Clutch could be a bit heavier, as could steering.
    That's about all I can think of after a week.
  5. #3195
    Jan 2008
    I've put some thoughts within yours:
    Quote Originally Posted by KWICKS View Post
    I've had plenty. Out in the hills it is lots of fun.
    Yeah I'll be laying off it in first - tyres won't last long otherwise. (Are yours Potenza S001?)
    Other thoughts:
    The SSV and XR6T were same so used to that.
    Better in sports mode with increased throttle inputs. Trouble is the "Eco-tips" get you changed up so early that you are always in a high gear/low revs where lag is prevalent.
    Two things I don't have but won't miss.
    Yeah my 14 yr old daughter says it's 'unnecessary' lol. Actually when I'm in the hills and revs are up I don't mind it so much. Setup Individual Mode so you have the sound off but other stuff on sports. Unfortunately that means you don't get the increased throttle response either.
    Ditto - I would never have considered ordering Moon White... But I love it with the black pack.
    After the crap in the SSV even the standard sound seems good. Do miss the Mac though.
    KESSY is about the only thing I wish I had. I found the option to make all doors open on first push of the button ok. Dunno if it's different with KESSY. Download the skoda app- the manual is searchable.
    Again - I wouldn't have ordered it- but it is really cool and handy to open remotely. Similarly with the pano roof - really like it.
    Yep I'm gonna buy a cheap mat to go over the mats lol
    Hear hear!
    I've only stuffed up twice. Only when rushed/trying to do multiple things quickly.
    Only used it once. The system is nice and quick to load at least. Lack of camera alerts sux big time. I've got the garmin up too.
    It varies with the dash light dim I believe which is through the menus so not very simple to get to. Make sure it is turned on to auto to select day/night mode. Mine wasn't and it's way too bright at night if not.
    Gear shift is nice.
    Clutch and gearshift is so easy.
    Assistance drops quite a bit via driving mode options.
  6. #3196
    Sep 2014
    Canberra
    I changed this the other night, under the car settings you can change it to driver side doors or all four doors.
    Candy White RS Wagon 162 TSI Manwell. 18" Black Pack, Sunroof, Tech Pack.
    Ordered: 22/09/14 -
    Built: 14/11/14 - ETA: 31/01/15 - Delivered 03/02/15
  7. #3197
    Same tyres Ian.
    Cheers for your thoughts. Seems the H6 Liberty was a proper luxury sports car of its day if you could ignore the fact it detonated engines frequently....
  8. #3198
    Oct 2010
    Same tyres Ian.
    And drank like a sailor on shore leave. Canton gets much better with time. Change the 'sound' setting to front or driver too, it sounds terrible in the other one. It's also really harsh on crap sources - CD sounds a lot better than pretty much anything else. You have an rs, so Columbus can play flac audio files. Make sure everything on your SD card is flac.
    My kessy is set to unlock all, but I find I press the key because someone always gets to the car first. Kessy seems like a great option for when you are by yourself, but not so if you carry lots of people.
    Lots of people here seem to come from Subaru's. Especially since subaru stopped making mostly good cars, and only had a few good ones now (compared to rest of market).
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
  9. #3199
    Erskineville, NSW
    Below in GREEN
    Not really had an opportunity to get it on boost for a couple of gear changes yet. Although I did elicit some wicked axle tramp in first. Seems not to cope too well with a boot full in first, better rolling on from second. They don't like it but lighter wheels & better tyres help. You're probably running 25-30kg per corner
    Other thoughts:
    No fuel tank lock or remote release is weird. It locks when you lock the car
    A little less responsive than hoped, maybe it will improve.Tight as a fishes bum - you'll need 5000km of getting into it and 15k to get it 98% bedded-in. Just keep loading it up and letting it over-run
    Sound maker sounds crap in Sports mode, better (less obtrusive) in Normal. I'd like to hear and feel the engine itself, no matter how quiet it is.You can turn that off with VCDS
    Kessy - need to read the book to get it to unlock all doors when I'm near, or in the car. Annoying everyone else at present by locking them out.There are lots of small features that go un-noticed unless you read the manual
    Carpets thin. Suspect they will wear through in drivers footwell before long.Buy some floor mats
    Clutch could be a bit heavier, as could steering. The steering might be adjustable with VCDS but the weighting won't change the lack of feedback
  10. #3200
    Oct 2009
    Mitchelton, Qld
    If ya want heavier steering whack in some superaloy LCAs. They'll do the trick.
