Page 39 of 42 FirstFirst ... 293738394041 ... LastLast
Results 381 to 390 of 419
Thread: New Nav map available in Skoda update portal
  1. #381
    Maitland, NSW
    i appear to have bricked it. now i cant get into the nav at all and when i hit factory reset on navigation it doesnt appear to do anything.
    this is what comes up when i hit the nav now.
    this is what came up after trying to update (with new sd card as the previous one didnt work so i took it back.)
    2.0L 6 Speed Mk3 2015 Skoda Octavia vRS 220 Wagon - Current
    2.0L 6 Speed Mk5 2005 Volkswagen Golf TDi - goneski
    2.0L 5 Speed Mk1 1995 Seat Toledo - goneski
    1.6L 5 Speed Mk2 1990 Golf - goneski
  2. #382
    Pacific Paradise QLD
    Ok a 32gb card does it and you cant skip any files So you download this file High12_P90_MRM_202045.zip to your hard drive
    You put a formatted 32gb Sd card into your computer
    You UNZIP the above file DIRECT to your SD card and when its done you should have ONLY these folders and one file on the card
    Mib1
    Mib2 Both are FOLDERS
    metainfo2.txt is obviously a text FILE
    Must be in root directory NOT in a folder
    Works for everyone else Eventually LOL
    Alternative method but much slower is to unzip to a folder on the HDD and then copy the above 3 from it to the SD card. Takes forever though. It wont find them if they are in another folder as only looks at the root of the card.
    I have used USB sticks with other stuff on them but as long as those three are on there and visible when you put it in car unit will find them
  3. #383
    Maitland, NSW
    yep, thats what i did. i'm trying again now and it's failed to copy halfway through and is now saying to format the drive again. thankfully im on hols and have some patience for this haha thanks for the replies.
  4. #384
    Do it with the engine running if battery gets down strange things happen with VAG cars
  5. #385
    Maitland, NSW
    i formatted my 64gb usb3 stick to exFAT (windows10) 'default allocation size' (my pc doesnt give me the option for FAT32) and copied the contents of the zip directly to the usb drive overnight. i tried it this morning and i still get the same error. im now reformatting and redownloading the zip.
  6. #386
    Quote Originally Posted by Rednut View Post
    EXFat is ok and Windoze CANT format anything bigger than 32gb in Fat32 you need a program like guiformat-x64.exe to do that
    Sounds like you have a corrupted download
  7. #387
    Maitland, NSW
    interestingly each time ive put the sd or usb into the car, it has a little popup that displays 'software download' as if it's recognised it's an update.. anyways, i'll report back later today once it's downloaded and i've tried it again, else, look for me on the news!
  8. #388
    Camberwell, Vic
    I'll go out on a limb a little here and wonder if the issue is the SD card itself. Most people use 32gb ones, class 10, SDHC - it may just be that your card is too big and new to be handled by the system. And I think XC needs to be formatted in a slightly different way which would cause the SD card reader in the car to have issues. I'd suggest you get a SD card that is 32gb, class 10, and try that. My newly purchased 2016 VRS, as I found out, has never been to a Skoda dealer since delivery (not for warranty or servicing or anything). So when I checked it was running the original firmware 0318 and original maps 2016.
    With no issue at all, I easily updated it to 2021 maps, then a week or so later when I had time, I updated the firmware from 0318 to 1433, the best available, again using the same card without any issue.
    I'd suggest trying this.
    2010 R36 (MY10.5), Biscay Blue, RNS510, MDI, Electric tailgate, sunroof, Superchips remap - SOLD
    2016 Octavia VRS wagon, moon white, Tech Pack, 18" black pack, electric boot, panoramic sunroof, Bluefin
  9. #389
    Camberwell, Vic
    I just checked, I use a SanDisk Ultra 32Gb, SDHC, class 10 running at 40 MB/s and it works. Maybe try and find one like that on eBay, and do it all again, as I think the size/formatting could be an issue.
  10. #390
    Camberwell, Vic
    And also, you may have to look at updating firmware too, assuming you cannot get the unit back up and running again.
