Page 20 of 42 FirstFirst ... 10181920212230 ... LastLast
Results 191 to 200 of 419
Thread: New Nav map available in Skoda update portal
  1. #191
    If it lets you do the update, then the maps are different, note down which version it is and I can tell you what I downloaded and installed about 2 weeks ago. Bet they are different.
  2. #192
    May 2016
    Richmond, NSW
    I just checked the Update portal and now there is MRM 2017/2018 available for download. I will download it overnight.
    Octavia Scout 135TDI MY16, Quartz Grey,
    Tech Pack, power seats, panoramic sunroof
  3. #193
    May 2016
    Quote Originally Posted by stu53 View Post
    Does it download for you? Mine errors out straight away with a file not found.
  4. #194
    May 2016
    Richmond, NSW
    My pc decided to reset at 1.00am so I had to restart it this morning. It is downloading ok so far.
  5. #195
    Jun 2016
    Thanks all, starting to Download the 17/18 now. Will report back with how I go/if it fails as above
    Skoda RS 230
    "The Grey Ghost"
    SG-TP-AB RS230 - Timeline
  6. #196
    May 2016
    This thing is totally broken for me - I get this error
    BlobNotFoundThe specified blob does not exist. RequestId:25482324-0001-003a-2203-f02836000000 Time:2017-06-28T11:43:53.2466245Z
  7. #197
    May 2016
    Richmond, NSW
    Download went smoothly. So glad I have unlimited download! Now to try installing it.
  8. #198
    May 2016
    Richmond, NSW
    Took an hour or so to install but works fine. It has some differences. I found one update to include a new piece of the Pacific Highway that has opened up near Frederickton.
    Raraku if you still have problems downloading I am happy to lend you my SD card with the update. I'm out in Richmond.
    I assume it will work and isn't somehow coded to my vehicle only.
  9. #199
    Feb 2017
    Belrose ,NSW
    did my update this morning -all ok
    here is a faster download link than the Skoda web site
    https://drive.google.com/open?id=0B3...jgtRTJNMHBaa28
    Regards
  10. #200
    Can you use an external hard drive via usb instead of a SD card? The ones I have are all 16Gb as I only use them on the GoPro
