Page 42 of 42 FirstFirst ... 32404142
Results 411 to 419 of 419
Thread: New Nav map available in Skoda update portal
  1. #411
    Feb 2024
    Geelong, Victoris
    Yes and once again is for MIB2 units ONLY Is a full map of 26GB I downloaded it 2 days ago to check what it was. Yes the files are named MiB 3 but................
    Will not work on MIB3 as in later models which only UPDATE and not replace the map and the file is only 2 GB and not available either on Skoda or VW portals yet
    Does anyone happen to have a working download for the P353 202345 from the Skoda site?
    I attempted to do it on the Skoda update site this morning, but just got the Blob error.
    Otherwise, I might just go with the seemingly available Volkswagon Download instead.
  2. #412
    Jun 2007
    Sydney, Australia
    The maps (P353) are common across both Skoda and Volkswagen. If you need to update use the VW ones.
    Flipper Dog
    Now - T-Roc R, Audi Q5
  3. #413
    Dec 2020
    Brisbane City, Queensland
    New update available now, MRM 2024/2025, on Skoda Update Portal. Current to calendar week 25 of 2024.
    File name is HIGH2_P373_ROW_202425.ZIP
  4. #414
    Pacific Paradise QLD
    Quote Originally Posted by johnthay View Post
    Thanks downloading it now Am going out in a few minutes so will se if it loads
  5. #415
    Jun 2007
    Sydney, Australia
    Flipper Dog
  6. #416
    Very good I put it in the car for about 10 mins and says 23.12 and I think prev was 22.6 So I guess its up dated If so I used an old Kogan 16gb Micro SD card plugged into a USB adapter and after loading on that a USB to USB C adapter and chucked it into the car Was formatted as Fat 32.
  7. #417
    Can someone confirm the Navigation Data base number as in pic above AFTER update please
  8. #418
    Dec 2020
    New update available now, MRM 2025, on Skoda Update Portal. Current to calendar week 48 of 2024.
    File name is HIGH2_P393_ROW_202445.ZIP
    Installed off USB drive this time. Completed in 20 minutes instead of around an hour for SD card.
  9. #419
    Did mine yesterday Just UnRARed the files to the root directory of the USB C stick I have all my music on and its loaded it Now 24.6 so presume that is map of 6th month 24 as last one was 23.12 meaning Dec 23
