I just checked the Update portal and now there is MRM 2017/2018 available for download. I will download it overnight.
If it lets you do the update, then the maps are different, note down which version it is and I can tell you what I downloaded and installed about 2 weeks ago. Bet they are different.
Thanks all, starting to Download the 17/18 now. Will report back with how I go/if it fails as above
This thing is totally broken for me - I get this error
BlobNotFoundThe specified blob does not exist. RequestId:25482324-0001-003a-2203-f02836000000 Time:2017-06-28T11:43:53.2466245Z
Took an hour or so to install but works fine. It has some differences. I found one update to include a new piece of the Pacific Highway that has opened up near Frederickton.
Raraku if you still have problems downloading I am happy to lend you my SD card with the update. I'm out in Richmond.
I assume it will work and isn't somehow coded to my vehicle only.
did my update this morning -all ok
here is a faster download link than the Skoda web site
https://drive.google.com/open?id=0B3...jgtRTJNMHBaa28
Regards
Can you use an external hard drive via usb instead of a SD card? The ones I have are all 16Gb as I only use them on the GoPro
