Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Night Time Assist - Steering turns on Fog Lights
    Dec 2012
    Sutherland Shire, Sydney
    So while messing around with VCDS the other day I noticed this option, so I turned it on, and it works
    When at low speed with the headlights on, if you indicate or just turn, the fog light on the inside of the corner turns on
    I can see it being handy in rural or poorly lit parking areas
    (Wonder how much they normally charge for this option)
    Dec 2008
    My mates Merc (G-something) and another mates A8 (Audi) does that. I thought their fog lights were stuffed until they pointed it out to me LOL...
    MY13GOLF2.0GTI/6SPDMAN/CARBONSTEEL
    MY15TIGUAN2.0TSI/DSG/WHITE
    Pacific Paradise QLD
    Quote Originally Posted by boogz View Post
    My Passat not only has static cornering side lights that light up when turning slow but Xenon headlights that swivel as well Came in Driver assistance package Cost $2600. Fog lights are separate to these cornering lights
    Jul 2010
    Quote Originally Posted by Martin View Post
    So while messing around with VCDS the other day I nooticed this option, so I turned it on, and it works
    Its called "Cornering Lights with Foglight Function".
    Its a $150 option at the dealers......
    ......or free if u have access to a vcds cable.
    I activated this a yr & a half ago, along with other vcds trickery.
    The Octavia with factory xenons also swivel when turning - "dynamic xenons".
    Mar 2013
    Doreen, VIC
    this is quite funny as you may have seen my thread and the issues I had with Skoda saying mine weren't optioned and it can't be done and also that the DRL globes next to the fogs (118TSI) have no wiring to them etc so can't be "turned on" from coding. When I pulled them out, they have the wires going to them!
    Jul 2010
    Quote Originally Posted by hitman View Post
    hey hey.......unfortunately i haven't been able to find any specific vcds for the non-vrs octavias.
    this is the coding i used:-
    Control Module > [09] Central elec / Coding / Long coding helper / byte14 / bit 5, Check the box.
    Exit
    Do it
    maybe the above will also work for the 118tsi
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Jul 2011
    New South Wales
    Came standard on the Superb.
    MY16 Octavia Scout 132TSI Premium - denim blue metallic, Tech pack, electric seats, panoramic roof, auto boot, roof racks, mud flaps and rubber mats
    Bowral, NSW
    I was quoted $250 for "cornering fogs" when I was first asking about the Octy... Then found out it was a simple tick box and didn't ask again!
    The cornering fogs activate when the lights have been manually turned on, and when the automatic headlights activate in tunnels and at night.
    They do not operate when rain has triggered the automatic headlights.
    Cornering fogs only operate when vehicle speed is 40-45km/h or under. (Both on steering angle or indicator)
    For mine at least, the steering wheel must reach 90^ (left or right) before the lights will turn on.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Apr 2012
    Cherrybrook NSW
    Yep, they cost me $250, but the option was already included on the car (ie I didn't specify it) - if I'd known at the time it was a simple VCDS change, I might have tried to get it "un-optioned"! Fat chance on that I'd say - they'd probably charge me $250 to do that!
    MY 22 Superb Sportline Wagon. Moon White.
    1985 BMW K100RS in JPS racing livery
    2019 BMW R1250GS Exclusive
    Quote Originally Posted by k_rider View Post
    Probably spot on there. Or maybe even more because of the labour charge to 'remove' the option that was added at the factory.
