Results 11 to 20 of 27
Thread: New brakes and tires - RS162
    Feb 2010
    Camden NSW
    Sorry I am late to this thread, and I can not help with the brakes issue, but I have suggestions on the tyres.
    Bridgestone Potenza RE003 are great in my opinion....
    2018 Ralyee Green RS wagon. Fully optioned.
    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
    Quote Originally Posted by Kachingg View Post
    I used volkstech in Heidelburg northern melbourne he was the one who recommended ATE pads
    But try any vw specialist near you they are a common item will be easy to order in and fit
    It is recommended to change your disc's at the same time as putting on ceramic pads
    I emailed Volkstech and I got a quote that was much more than I was expected. Lets just say I emailed another Volkswagen workshop, listed as an ATE Brake Center, that was supplying the part I wanted for much cheaper. I'm sure if I asked them to install it would still be cheaper that what I got quoted. I'll leave it at that.
    HSY were the importer but ATE appear to have brought distribution in-house.
    Products - ATE Australia
    ATE Brake Centres - ATE Australia
    I actually emailed HSY and they told me to find my local ATE Brake Center. Seems like HSY is the distributer (as the website suggest) and not dealing with the end customer now.
    Quote Originally Posted by Tigger View Post
    I'll keep that in mind when I eventually go through my Michelin PS4. Thanks anyway!
    Mar 2009
    Quote Originally Posted by Slugoid View Post
    Can you PM me the cheaper VW workshop.
    I'd say HSY won't sell direct to keep their dealers happy. Interesting as I can buy other parts direct from them!
    Sent from my SM-G965F using Tapatalk
    MY07 Red GTI 3 Door
    Oct 2018
    Do you mind PM'ing me with cheaper workshop too pls?
    Oct 2018
    I have the original Potenza's on mine, 2 yrs old 45,000kms. Fronts are badly feathered but decent amount of tread left just so noisy as! Apparently these are common issue with them. Only reason I've managed this much kms is I always keep pressures high. What's the max pressure you guys run on the 18"?
    Quote Originally Posted by WDF View Post
    Check pm!
    I run 250kPa/36psi all round on my RS wagon with OEM 225/40R18, which is what the placard recommends. If I have 3 passengers in the back I'd go 40psi at the back. Since I only got my car 2 months ago, and new tyres a month ago, I have no idea if that's a good setting or not, but I will be monitoring the tread level closely since I don't even know if the alignment is correct or not!
    Oct 2018
    Check pm!
    Thanks mate got the PM!
    Is there any harm other than harsher ride in always running max pressure on OEM 18's even when car not fully loaded ie.
    240 - 250kpa front
    320 - 330kpa rear
    As long as it's below the max quoted on the tyres (which is like 50psi for my Michelin's) there's no immediate harm.
    Harsher ride, more wear in the centre of the tyre (depending on camber), and maybe less contact to the road if you go insane like 45+ psi. In fact, it's better to go a bit more than under the recommended as low pressure can cause tyre flex and even less contact path to the road.
    Apr 2017
    belgrave victoria
    Glad you got them cheaper i got them as part of a package (swapped to golf R brakes from the original ones)
    I went on a run up the reefton spur last week and the pads worked fine no fade and got better the hotter they got the mark 6 gti in front of me had his brakes smoking at the end of the run and i could touch my calipers with my bare hand (for a few seconds anyway) color me impressed
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Erskineville, NSW
    i run 38psi but have run 42psi fairly often in the past.
    I've never experienced a feathering problem in either set of RE050A I've had but I cross-rotate them every year and the change in rotational direction helps reduce any high spots.
