Page 12 of 21 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 203
Thread: Mysticality's Light Thread!!
  1. #111
    Bowral, NSW
    I was considering mounting a Unibar to the front of the vehicle... but IMO it'll look too ugly.
    My only options then, are some surface mounted units, or an LED light bar mounted to the metal brace behind the bumper. :/
    But they do suit the Scout, I must say.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  2. #112
    Apr 2009
    Northern Tasmania
    Yes the Unibar could look better, but it gives reasonable protection from someone backing into the lights. As well as somewhere to mount them.
    I had a look for a way to get wires through the firewall when I was doing my towbar (to get a fridge power wire through) and it looked very well sewn up at any hole. Very difficult to get a wire through. I vaguely remember seeing a wireless switch for driving lights which sends the switch signal wirelessly through the firewall for just this problem.
    Like this:
    LIGHTFORCE WIRELESS DRIVING LIGHT LIGHTS LAMP LAMPS WIRING HARNESS KIT 12V VOLT | eBay
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  3. #113
    Gosford Central Coast NSW
    I just ran amp wiring through the firewall a few weeks back.
    I ran it through the main wiring grommet which lives way down behind the battery in the engine compartment... basically pull off the trim in the passenger footwell under the dash and pull back the carpet/sound deadening a little, feel around with your hand and you should be able to trace along the large wiring loom through to the grommet in the firewall. I ran the wire from within the passenger compartment by taping it to the end of a small sharp philips head screwdriver and poking it through the grommet beside the wiring loom (away from the main bunch of wires, in the side of the grommet - its very large, thin and a bit conical). Then, I fed through about 150mm of wire until I could just see it down behind the battery, at which time I was able to hook it and pull it up to where I could work with it.
    Hope that helps... I was looking around for ages for another place to run it, that was the best I could find. Might be better but I don't know
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  4. #114
    Jun 2012
    Dunlop ACT
    I too have been pondering getting a wire through the firewall. As much hassle as it is I need a switch – on long straights with decent lights there are many times I am happy to run the high beams but not the spots with oncoming traffic or when following someone (like 2 phase dipping…..). Have not found anywhere straightforward – gldgti may have solved it-
    But then there is the problem of mounting a switch in/on a nice new dash. The blanks under the climate control look promising – but then I assume the switches for there are far from cheap and there is the problem of pulling the dash to bits (at least to some degree) to get to them. Don’t like the sound of that….
    wfdTamar seems to have found the solution :-
    I have been looking at lightforce HIDs and their loom and this remote switch (switch really buried in their website – not sure yet if it is a suitable relay..) looks like the answer…….
    Ivars –
    Quote Originally Posted by IBN View Post
    I've used a light bar successfully on my Scout. It has been braced to the steel bar behind the plastic bumper so shake and vibration are minimal, even on dirt roads. The install is Ver1.0, so next time the whole thing would be more refined.
    Considering I used some old Cibie Oscar+ lights which are quite heavy, I'm quite happy with the result. Night driving is once again a pleasure.
    Cheers, Ivars.
    Did you need to space the light bar out much?
    What did you use as a spacer (saw one on the weekend with a dozen ¼” washers……..)?
    Did you purchase a loom or make up the transistorised relay yourself?
    I have been looking at that plate behind/in/under the bumper & thinking about mounting some smaller rectangular lights on a bracket from it behind the grill (replacing the grill with a mesh one from superskoda) – but figure its probably not worth it for the bit of extra light that I would get from lights that would fit – and they would likely be in front of the air inlet or at least put hot air into it…).
    MY11 Skoda Octavia vRS ("GT") wagon, TDI, DSG, candy white, downsized (upgraded) to 16" alloys & 225/50 R16s, leather, tint, towbar, 70w HID lightforce strikers
  5. #115
    Bowral, NSW
    Quote Originally Posted by DunlopRS View Post
    Thats why I'm gonna go with LED.
    Less heat, and all this new LED tech is making it worthwhile. They're using LED's as halogen/HID replacements in stock headlight units now. If that isn't promising, I don't know what is.
    I put my switches here. Nice and hidden. Spot them in the photo. :p
  6. #116
    Apr 2009
    Northern Tasmania
    I need/want the switch somewhere very handy. What about the button on the steering wheel that dims the lights on the steering wheel buttons (left side, bottom right)? Don't need to dim the button lights. Do the newer wheels have that button?
    20120717_145519 | Flickr - Photo Sharing!
    Or probably better still, what about using the rear fog lights button (main light switch pulled out twice)? You're not likely to need the rear fog lights. Easy to kill the driving lights. Should be able to work out which wire it is.
  7. #117
    Jun 2012
    Dunlop ACT
    Different steering wheel. That would be a difficult one to tap into too (only pulse & not on/off??). I am also a little adverse to doing significant fiddling with the dash/linings unless absolutely necessary…
    I like the idea of the rear fog light switch. Any ideas if this could be done without upsetting the car (the electronics that is)?
  8. #118
    Jun 2012
    Dunlop ACT
    Quote Originally Posted by Mysticality View Post
    That's neat. I am sure I would not get the lining back as new...........
  9. #119
    You could probably use a small solid state relay powered directly from the lighting circuit to power the big relay for the lights. SSR's need very little juice to operate, so are quite good for not upsetting circuits with bulb detection/etc.
    So, basically you could just mount your little SSR in the trim, perhaps right near the light cluster (out of the way). You could even use te SSR to switch one of those wireless switches that was linked to above, if you were keen. Or, let the SSR switch power for the driving light relay (simplest way would be to switch the ground wire for the coil, you would need only run a single wire from the driving light relay to the SSR, wherever you put it). No comment about whether or not that is good practice
    '99 A4 Quattro 1.8T
  10. #120
    Apr 2009
    Northern Tasmania
    There's plenty of room behind the light switch to mount a relay. I've taken the lower RH dash off twice now so can describe how to do it with busting things if anyone wants me to.
