Page 9 of 21 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 203
Thread: Mysticality's Light Thread!!
  1. #81
    Jan 2012
    i agree the standard halogens ARE awesome. compared to a 1981 corolla.
    the HID kit only makes it better. i dont think there is a difference in the actual headlight assembly. behind the lens is the fitting for the light globe, or burner, and can easily be removed. the rest is done in the car with the headlight levelling and washers.
  2. #82
    Gosford Central Coast NSW
    I cant help thinking that tinting the lights then doing an HID conversion is a bit like adding 20kg lead ballast to the car and then removing all your doorcards and sound deadening to get it back to stock weight again
    But hey, whatever floats your boat
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  3. #83
    Jan 2012
    boat? mate no one was mentioning skylines
  4. #84
    Bowral, NSW
    Quote Originally Posted by zei20t View Post
    The stock Xenons are the AFS type. (Motors inside the unit that make it turn side to side, as well as up and down.)
    If anyone in the Sydney area has Xenon's and is willing to let me take the bulbs out to have a look inside, that would be excellent.
    The low beams of the Halogens are fine. Its the high beam thats useless.
    Even compared to my mother's '06 Kia Rio (H4 Halogen bulb)... That being said, the high beams in that are really excellent.
    This.
    Quote Originally Posted by woofy View Post
    But you nightshaded them, so whatever they were will be far worse now...
    Yeah, I know.
    But they look really cool.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  5. #85
    Jan 2012
    Quote Originally Posted by Mysticality View Post
    quoted for truth
    also, didnt realise the motors were on the headlight unit. i wish i could see one too!
  6. #86
    Can take a look at mine if it helps.
    Sent using electrickery
  7. #87
    Bowral, NSW
    I have the car booked in tomorrow for the blinker issue. (Again. Result of using aftermarket HID's)
    I'm going to ask the parts guy for the part number of the Fabia Monte Carlo's projector unit and the part number of the Octavia's halogen projector unit. Also, price of a HID headlight unit.
    For those who don't know; the Fabia Monte Carlo has a bi-xenon style projector unit. (I.E. High beam is exactly like low beam, just with no cutoff)
    If I can retrofit the Fabia's unit into the Octavia's headlight housing, I can run the motor that drives the cutoff off of the wiring loom which I will have installed for the LED driving lights.
    That way, there's stock halogen high beam, as well as the projector producing high beam.
    And if I can get the stock HID bulb and controller unit retrofitted (hopefully then it won't produce the errors that the aftermarket unit has), I'll have bi-xenon, halogen high beam AND the LED driving lights.
    Snake Racing online store Australia - Shop for Trick Off Road Componentry for your 4x4, 4WD vehicle
    To answer the inevitable question: Why.
    Because I light lights. I like seeing whats infront of me at night. Especially down the Southern Highlands back roads.
    I'm going to point you to a sig-pic of mine from another forum: http://a1.sphotos.ak.fbcdn.net/hphot..._2312439_n.jpg
    I was used to having a lot of light, and coming to this vehicle... Well, its kinda stunted.
    That being said, my little Rio WAS a project car. I don't intend to do THAT to the Octavia. You can breathe a sigh of relief. :p
    I do, however, drive a lot of k's. The car is 5.5months old and its just hit 20,000.
    A lot of those have been at night. Down back roads. With Roo's and wombats and things that'll destroy the Skoda.
    Also - If I can do something that'll help out the community as a whole... Why not?
  8. #88
    Jul 2010
    quoted for truth
    there's a big difference behind the scenes, between an afs xenon headlight & halogen projector headlight.
    here's some mechanics about the afs xenons - its motors & sensors.
    u can also tell by physically looking at the headlight cluster - with the xenon afs ones, there is bigger visible gap between actual projector & housing. this enables it to "swivel". there is also a indent/cut where it says "octavia"
    a halogen projector headlight cluster won't have this indent/cut.
    xenon afs
    non-xenon
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  9. #89
    Can one of you Skoda headlight guru's please confirm the bulbs used in the Octavia's headlight assembly. My brother just recently purchased a new 2012 Octavia and would like to upgrade the bulbs with Phillips Diamond Vision 5000k replacement bulbs.
    From what i can gather in this thread, im guessing:
    Main headlight = H7
    High beam = H1
    Parker Light = standard T10 wedge globe.
    If someone could confirm it would be appreciated.
  10. #90
    Bowral, NSW
    Low: H7
    High: H1
    Parker (Non-vRS): T10.
    T10 must be incandescent, or resisted LED.
