Page 1 of 21 12311 ... LastLast
Results 1 to 10 of 203
Thread: Mysticality's Light Thread!!
    Bowral, NSW
    If you'd have seen my first car - a 2007 Kia Rio - you'd understand. Over 500W of driving lights, fog lights, LED's... The whole shebang.
    The Octavia vRS wagon wouldn't look as good with a barrage of driving lights on it, so I think I'm going to go a more elegant LED light-bar route.
    EDIT: Rio: http://a1.sphotos.ak.fbcdn.net/hphot..._2312439_n.jpg
    Oh, what a feelin'
    Yes there is a point to this. I do a lot of camping, drive a lot of dirt roads and all of the back streets around the Southern Highlands are small, dark, windy, and covered in wildlife.
    Mods so far:
    Low-beam aftermarket 6000K HID
    High-beam aftermarket 6000K HID
    vRS Parking lights (on with low beam) - Advise against. Seem to be the cause of my Body Control Module carking it. $500 repair job, minus labour.
    Internal LED
    To do:
    Chinese LED tail lights *OR* The black aftermarkets
    Probably going to go with the chinese ones, due to the brightness of the reverse beam.
    2x SnakeRacing.com.au Dually D2 Driving
    1x SnakeRacing.com.au 20" E-Series light bar
    CAN-BUS compatible white LED numberplate lamps
    Cargo-area LED lamps from VW.
    Coming/Leaving home via Fog VAG-COM coding.
    Jul 2010
    damn....u sure luv ur lights!!!!
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    If you wouldn't mind sharing which LED license plate lights you get that don't throw a bulb out warning I'd appreciate it.
    The 'CANbus error free' lights I got look the part but car detects bulb out. I don't want to add inline resistors so am happy to put up with the errors until I get a proper replacement. The ones I have now work fine in a MkV Golf, and in my previous A3 but newer cars seem to be more sensitive...
    Gosford Central Coast NSW
    Dont you mean "Free CANBUS error" ? :-P
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Bowral, NSW
    @Kamold- Sure thing. Currently waiting on some eBay ones.
    I found an issue today, whilst sitting outside the high school. I noticed in the main door reflection that the right hand front indicator bulb was stuck on. CANBUS didn't throw an error for a good five minutes. The only way to turn the bulb off is to remove it.
    This includes locking the car. The bloody thing stays on even if you leave it for an hour.
    I removed my HID's, returned the bulbs to stock and will take it in for a warranty check tomorrow.
    The errors aren't free, you have to buy aftermarket globes to get them
    Brisbane, Australia
    Did you have to wire in the parking lights? I've read that they don't work here as the DRL's are the in the place of them? I want mine to work!
    Also, how do you find the low and high beam at 6000k? I looked at some and the length of light throw seemed to diminish anywhere above 5600k. I've got Xenon low beam but wouldn't mine looking at a white high beam. What brand are you using?
    Thanks!
    Bowral, NSW
    I spliced the parkers into the low-beam.
    Yeah, we have the LED DRL's, and so we don't have the little T10 parkers... Its a shame, really.
    My entire system is back to stock until next Thursday when I can get this indicator issue sorted, will report back on it.
    I actually really quite like the 6000K, although 5000K would probably be a much more 'European' look. The high-beam reflector is almost perfect for the HID bulb, too. Perfect light throw.
    I'm using a cheap generic $60 eBay system that I had previously in my Kia Sorento. The kits have done a good 25,000km so no real complaints.
    Bowral, NSW
    Body Control Module swapped out for a new one, indicator issue resolved.
    Advise against the parking light mod.
    eBay HID kits (high and low) seem to still be fine. Vehicle at 7,500km.
    eBay CANBUS-compatible LED's didn't work. Will have to find alternatives.
    Interior lights still working perfectly.
    Waiting to hear more about LED tail lights.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Jul 2010
    Quote Originally Posted by Mysticality View Post
    i'm guessing u put hid in ur high beam aswell - i hope u realise putting hid globes in highbeams r next to pointless.
    hids r not 'flash' friendly. they're 'startup' characteristics don't go in favor of 'highbeam flashing'.
    that's why a lot of cars that come equipped with bi-xenons still have highbeam reflectors with halogen globes. take the superb as an example.
    then again if u do a lot of driving (country) n u use ur high beams alot, then i guess u have a point.
