Page 19 of 21 FirstFirst ... 91718192021 LastLast
Results 181 to 190 of 203
Thread: Mysticality's Light Thread!!
  1. #181
    Sep 2010
    QLD
    The one on the Superb does look like it has an spare halogen for flashing duties. The Octavia one looks different, perhaps non-RS system? as the Bi-Xenon on my RS didn't have an extra Halogen bulb.
    The pre-facelifted Tiguan does have an extra Halogen but not for flashing, it's for casting light into the corner, perhaps they have changed the system around with the new facelift (doesn't seems to have corner light now).
    2011 Tiguan 125TSI - SOLD
    2014 Race Blue Octavia RS 162TSI Combi
    Check out my leather work ----> http://pedsnro.blogspot.com/
  2. #182
    Bowral, NSW
    Quote Originally Posted by k_rider View Post
    I seem to remember reading somewhere that cars with bi-xenon lights (ie HID in hi and lo beam) had an extra halogen bulb fitted for the flash function. I have no idea if that's true or not, but seems plausible as it eliminates the time needed for the HID bulb to start.
    A mate of mine had a 2012 SP25 with bi-xenon, the bulb ignited and the shutter moved when he flashed. Looked funny, two tiny winking white lights.
    ^^^^ What GTR27 says.
    My query was in relation to those that have replaced the halogen high beam with a HID - how do they flash with effect.
    You'd want to flash and hold for a second to give the bulb some time to run before cutting the power.
    Quote Originally Posted by 99Reza View Post
    There are HID kit out there specifically for Halogen H3 bulb (low and high beam in one bulb). This particular HID kit will have a motor operated shield (similar to Bi-xenon) in front of the bulb. When hi-beam is needed, it works very similar to OEM Bi-Xenon.
    My friend has one on his Camry, works ok and comes with an extra wiring for the motor.
    H3? I think you mean H4.
    H4 bi-xenon kits are terrible. Worst thing in the world. Should be banned.
    The newer BMers I've seen (you know what bmers look like - twin angel eyes) have the outside lens for Bi-Xenon, the inside lens for cornering halogen. May also use as flasher? I don't know.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  3. #183
    Jun 2014
    After reading about the issues with the BCM, I've decided to keep it simple. Ordered some of the Osram Nightbreaker Unlimited globes, to see how much of an improvement they will make first off. Pretty cheap experiment and will fit my motorbike anyway.
    Then will likely add some supplementary lights behind the grille. Just tossing up whether a LED light bar is a good choice - as I've read they're a rather spread beam, and if mounted low behind the grille, may just end up lighting up the road directly in front of the car? Can't bring myself to shelling out $1000 for a name-brand kit, so will look around for other options. Ironically, may just end up with small circular halogens in the end.
    Skoda Octavia v/RS - 2012 Petrol 6MT
  4. #184
    Apr 2009
    Northern Tasmania
    Seeing where Mysticality had his smaller led light bar mounted I thought I'd put mine in there rather than over the number plate as I originally was going to. Using one of these:
    Cosmoblaze 100W Single Row Series CREE LED Light Bar for Safer Night Driving
    BTW - the wiring kit that comes with it is wired up for use off road and independently switched (that is - nothing to do with the headlights). It's not for use with the high beam. I had to rejig it to have the light bar turn off when high beam is dimmed.
    Blimey that front cross member is tough stuff. Pretty much demolished a good drill bit set getting through it.
    It's a 20" wide 10 x 5 watts Cree's.
    Mysticality's Light Thread!!-2015-06-30-16-12-23-jpg
    Light's off
    Mysticality's Light Thread!!-2015-07-02-16-30-49-jpg
    Low beam (I have Philips Xtreme's)
    Mysticality's Light Thread!!-2015-07-02-16-32-13-jpg
    High beam. Note that the low beam projector light is shuttered, so on High beam it opens up and those lights are high beam as well as the actual High beam lights.
    Mysticality's Light Thread!!-2015-07-02-16-32-38-jpg
    High beam with lightbar
    Mysticality's Light Thread!!-2015-07-02-16-33-03-jpg
    I put the switch down to the left of the seat (the thing next to it is a controller for my stereo).
    Mysticality's Light Thread!!-2015-07-02-16-33-27-jpg
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  5. #185
    Jan 2013
    I thought about doing the exact same thing, was worried about blocking the intercooler..might go ahead and do it anyways lol
    Sent from my C6903 using Tapatalk
  6. #186
    Apr 2009
    Northern Tasmania
    Tried it a bit last night. Well, I'm a little underwhelmed with the results. I've had euro beam halogen driving lights (shown earlier in this thread) before on other cars and this is nothing like those. It's a bit wimpy. Maybe because it's behind the grill, or low down, or just not very bright, or able to throw the beam very far. Or possibly there wasn't anything close enough for the light to reflect off. Maybe I should set up some cardboard wallabies on the side of the road.
    The light bar I got has a combo beam - flood on each side and spot in the middle. I've only tried it a bit and it's possible the middle bar in the grille is blocking some light. but it doesn't seem to do a real lot. I'll know more this weekend as I'll be driving in the dark tonight.
    Not really worried about blocking any airflow at the moment - we had -2 last night (it's still 0) and the other day it only got to a max of 7! (That is a bit unusual). My thinking is any air blocked by the bar is going to go around it and still hit the radiator anyway (there is a limit to that theory though). Never had my car temperature waver from dead on 90 degrees.
    If I can't get an improvement I might try it over the number plate and/or some normal driving lights.
  7. #187
    Erskineville, NSW
    See the gaps around the condensor? Get some foam & block them off so all the air is forced through the triple-pack.
    This guy seems happy with his Rigid Industries Light bar - do you think there's any difference in quality / output. Rigid Industry units appear to be twice the price but we all know price !=quality.
  8. #188
    Apr 2009
    Northern Tasmania
    The bar I got isn't an el cheapo like the thousands on eBay. It's about as good as a chinese made one is going to get. I found a site that reviewed about half a dozen of the better brands and this was on it because it's one of the few that is IP69K - most are IP68, which I took to be an indication of the quality. All the specs are similar to the equivalent to the closest Rigid one. About to head off to Coles Bay so I'll see what it's like properly.
  9. #189
    Erskineville, NSW
    If it's a good unit then it's probably height. I won't even question the wiring setup - you probably have more knowledge than most on that subject.
  10. #190
    Apr 2009
    Northern Tasmania
    Yes, the height or being behind the grill. It doesn't look like it obstructs it at all, but it might.
    Friday night through windy wallaby country it doesn't have any spot effect at all to speak of, but really just amplifies the pattern of the standard lights on high beam. Not useless, but I'd like a bit more spot effect like that Rigid one with a narrower beam pattern probably would have.
    Just got a set of these for $225 shipped (using code JULY4TH). Expensive but supposed to be Canbus friendly. It actually mentions Golf V so should be no problem.
    50Watt H7 Canbus HID set
    H7: Morimoto Elite HID System - HID Systems from The Retrofit Source Inc
