Octavia uses projector low beams, be they halogen or xenon. If using xenon kits in halogen Octavia headlights, you use the headlight leveller to angle them down by 0.5, so they hold straight and true.
Coming/leaving home via fog lights - problem solved! :)
Now, to answer your question - I did have HID in both high and low at one stage, but I don't think I'd go back to HID in the highs. (Have them in the low again, to see if this new kit will play havoc with the BCM - all seems okay so far)
I have an 80w LED light bar located in the lower grille, and have had for around 170,000km. Works really well.
I now have a 180w LED light bar on the roof so the lower one is disconnected - haven't been bothered to take it out yet. :) (Is next to brand new, got a warranty replacement not long before I bought the other one)
In the attached image, you can see both light bars.
If I wanted and explicitly cared about the stealth look, I'd go the smaller (20") bar in the grill again - its been great.
http://www.vwwatercooled.com.au/forums/
