Page 17 of 21 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 203
Thread: Mysticality's Light Thread!!
  1. #161
    Re: Mysticality's Light Thread!!
    They must have changed the lights. Mine stay on slightly until I lock the car. Then they turn off. Superskoda kit.
  2. #162
    Bowral, NSW
    There's a low voltage sent through the interior bulbs all the time... Thats what you're seeing.
    Its not powerful enough to power the incandescents, but it can power the LED's.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  3. #163
    Nov 2012
    Melbourne, VIC
    Some of the LEDs I've put in my house do the same thing - stay on at a low level or flicker for some time after they're switched off. Must just be an LED thing.
    MY10 Octavia Wagon in Candy White, 118TSI, DSG7
  4. #164
    Jun 2014
    Bit of a thread dig...
    Has anyone had any luck/advice on replacing the H1 high beams on a 2012 Octy with HIDs?
    I figure that as the low-beams stay on with the high-beams, it should functionally work well (no warm-up issue).
    Thinking a 55W HID kit would throw a lot of light, and not draw any more power or produce any more heat, than stock halogens.
    Would much rather super-power high-beams, than adding in any additional light fittings.
    Skoda Octavia v/RS - 2012 Petrol 6MT
  5. #165
    Pacific Paradise QLD
    Quote Originally Posted by Andres View Post
    They are illegal to fit without washers and auto levelling and dont work well if fitted in the stock reflectors as they are not designed for HID and tend to flare like the sun.
    Not that it seems to stop some people from doing it.
  6. #166
    Jun 2011
    Darwin, NT
    Don't even think of it in your low beam as that's when you'll have issues with dazzling lights for oncoming traffic and legalities but in High Beam they're fantastic.
    My Yeti has Bi-Xenon so it has a HID bulb permanently on with the lights then a shutter drops for low beam. This is how most of them work.
    My previous vehicle was a MY05 WRX which had exactly as your Octy, permanently on low beam with the lights then a complete second reflector and bulb for high beam. I fitted HID in this lens and it works great. You only use high beam when your not approaching or following other vehicles so there is no problem with dazzling other drivers and you get a bucket load more light.
    The down side though is if you want to flash other drivers. Due to the warm up you don't get a bright flash of the head light but I guess my current Yeti is exactly the same,
    Happy Days
  7. #167
    Jun 2014
    I understand, however, much like spotlights or even high beams, no oncoming traffic would see then if fitted in lieu of the H1 halogens.
    Quote Originally Posted by joel0407 View Post
    Happy Days
    Yeah, that's what I thought. Previous car had large spotties, so missing decent light output, when on the open road.
  8. #168
    Oct 2010
    I second HID's in the high beam. The low beams are good enough for when you need low beams, and when you're using high beams no one else is around anyway.
    Some 50w HID's (no more than 5K colour temp - 4.3K is better) in your high beam will sort out the lack of guts.
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
  9. #169
    Erskineville, NSW
    Happy Days
    It's a 2012 Octavia. They have projector low beams with halogens standard & take HIDs really well. It's not like a Golf with reflector housings
    I've been runing HIDs in the projector housings fro the past 75,000km in Scandinavian mode (permanently on). I pass about 3 HWP cars a day & they don't look at me twice.
  10. #170
    Jun 2014
    Quote Originally Posted by GTR27 View Post
    Yeah, would definitely not go the wanky blue colour temps.
    While I reckon you're probably right, the low beams will get a Osram Night Breaker Unlimited or Philips Xtremevision upgrade. I like the courtesy lights and apparently HIDs don't play nice with variable voltages (ie fading).
