cant 'see' your intake cleaner, therefore your videos are invalid
kidding, that's a great outcome!
DIY mix looks good!
while im under warranty ill still stick with a 'branded' product. no offence to your solution. in 2 years I can do whatever
id do it, just not while under factory warranty
the solution of your solution is good lol
Hey brad, what's the missing 100ml from your first formulation (assuming the litre you mentioned in an earlier post)? Presumably you atomise the mixture somehow (eg with a spray bottle) when running it into the intake manifold?
MY 22 Superb Sportline Wagon. Moon White.
1985 BMW K100RS in JPS racing livery
2019 BMW R1250GS Exclusive
I think it's missing the ability to do simple addition.
It's not an exact measuring process - I just throw in a bit of this & a bit of that & measure it by eye. I make Long Island Ice Tea the same way.
just a spray bottle either through the air temp sensor hole in the inlet manifold or dissconnect the MAF and come in throught the air inlet pipe before the turbo (so the mix goes through the turbo & the IC, etc). The former would concentrate mainly on the inlet valves, the latter would be cleaning everything & possibly less effective on the valves.(assuming the litre you mentioned in an earlier post)? Presumably you atomise the mixture somehow (eg with a spray bottle) when running it into the intake manifold?
You can use one of these 2L units inverted (remove the internal pickup tube)
or a 5L
I have a service due next week so I'll probably do mine again this week. I think it's preferable to change the oil soon after carrying out a treatment.
Look up "revive turbo treatment" on youtube for some ideas.
Yes, always do this just before a service, so any dislodged items are cleaned out and don't start suspended in fluids.
2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
Thanks brad. Looks like you've been rifling through my shed, I bought each of those exact same spray bottles for spraying sealant onto my new concrete pavers! Great that I can press them into a new role. Now to take that leap of faith...
