Results 21 to 30 of 32
Thread: MY12 Octavia RS TSI DSG 'Injector Fault'
  1. #21
    Jan 2012
    cant 'see' your intake cleaner, therefore your videos are invalid
    kidding, that's a great outcome!
  2. #22
    Erskineville, NSW
    Quote Originally Posted by zei20t View Post
    I made some type of magic mix for it - 500 water: 200 turps : 100 degreaser : 100 metho
    I think this time I'll try 400 water : 200 turps : 100 degreaser : 200 kerosene : 100 petrol. The degreaser is mainly to get the water to emulsify with all the other solvents.
  3. #23
    AFAIK only the MK3 TSI engines have 8 injectors. My (MK2 Octy RS) TSI has only 4.
    ^ this is true. Only the Gen 3 version of the EA888 engine from 2014 onwards have 8 injectors.
    Good result from the DIY clean Brad. I used the Nulon cleaner in my Mk6 GTI about a year ago when i first got it but haven't done a clean since. Might try your DIY concoction.
  4. #24
    Jan 2012
    DIY mix looks good!
    while im under warranty ill still stick with a 'branded' product. no offence to your solution. in 2 years I can do whatever
  5. #25
    Erskineville, NSW
    none taken
    With things like this there's a leap of faith even after you've researched & pondered.
    I've been faffing about with cleaners, etc for a long time. I first fitted water injection to an XT Falcon in 1982.
  6. #26
    Jan 2012
    id do it, just not while under factory warranty
    the solution of your solution is good lol
  7. #27
    Apr 2012
    Cherrybrook NSW
    Hey brad, what's the missing 100ml from your first formulation (assuming the litre you mentioned in an earlier post)? Presumably you atomise the mixture somehow (eg with a spray bottle) when running it into the intake manifold?
    MY 22 Superb Sportline Wagon. Moon White.
    1985 BMW K100RS in JPS racing livery
    2019 BMW R1250GS Exclusive
  8. #28
    Erskineville, NSW
    Quote Originally Posted by k_rider View Post
    I think it's missing the ability to do simple addition.
    It's not an exact measuring process - I just throw in a bit of this & a bit of that & measure it by eye. I make Long Island Ice Tea the same way.
    just a spray bottle either through the air temp sensor hole in the inlet manifold or dissconnect the MAF and come in throught the air inlet pipe before the turbo (so the mix goes through the turbo & the IC, etc). The former would concentrate mainly on the inlet valves, the latter would be cleaning everything & possibly less effective on the valves.
    You can use one of these 2L units inverted (remove the internal pickup tube)
    or a 5L
    I have a service due next week so I'll probably do mine again this week. I think it's preferable to change the oil soon after carrying out a treatment.
    Look up "revive turbo treatment" on youtube for some ideas.
    Attached Thumbnails Attached Thumbnails MY12 Octavia RS TSI DSG 'Injector Fault'-pump_sprayer_2l_2-jpg   MY12 Octavia RS TSI DSG 'Injector Fault'-$_35-jpg
  9. #29
    Oct 2010
    Yes, always do this just before a service, so any dislodged items are cleaned out and don't start suspended in fluids.
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
  10. #30
    Apr 2012
    Cherrybrook NSW
    Thanks brad. Looks like you've been rifling through my shed, I bought each of those exact same spray bottles for spraying sealant onto my new concrete pavers! Great that I can press them into a new role. Now to take that leap of faith...
