Results 11 to 20 of 32
Thread: MY12 Octavia RS TSI DSG 'Injector Fault'
    Jul 2014
    Quote Originally Posted by zei20t View Post
    Use a good quality engine oil too, it will help stop carbon and oil build up in the manifolds and over injectors.
    getting the engine up to temperature and keeping it there for a while is also good for engine maintenance.
    I reckon if you use poor quality oils in any turbo engine then carbon and oil build up will be the least of your problems.
    Erskineville, NSW
    Quote Originally Posted by Gerrycan View Post
    If anything goes wrong during, or subsequent to, your application of the Nulon treatment then wouldn't the warranty be compromised? Probably undetectable though I suppose.
    Would not have thought it would be necessary until about 30k or 2 year service.
    I would be surprised if the low end engines like ours will ever receive two injectors per cylinder like the 2 litre does. Not sure about the 1.8 litre though, I thought I read somewhere that it does.
    From my reading on the carbon build up subject, most of the problems seem to be associated with the EGR (pcv valving) system and lots of short cold journeys do not help.
    Doing anything not in the book could compromise warranty. That's where we toss a coin and decide if we take a chance. Getting VWA to warrant carbon build-up would be near impossible.
    I'd like to thank you for the reminder. I fitted a Forge Catch Can to mine (possibly in October or November last year around the same time as the interim service but I didn't make note of the date). I checked it every couple of weeks and it didn't seem to be doing a thing and forgot about it & haven't checked it this year.
    I just had a look (5000-7000km travelled) and the catch can was well over the max mark. I filled a 500ml jar with horrid brown water-like garbage and foamy scum.
    My oil level is only down 3mm from the top of the cross-hatch.
    I can imagine this goop going into the inlet, the water evaporating off and the remainder coating the valves.
    80% of my journeys are 40km+. The engine gets nice warmed up nicely. BTW, EGR isn't tied into the PCV (as far as I can see).
    Edit: Just found it - fitted 24/10/14 at 143500km. Now at 149500 = 6000km travelled
    Dec 2008
    Sydney/Canberra
    It's that film that sits in your intake, gets heat-cycled then turns to sludge, gets more heat, then eventually bakes on.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Erskineville, NSW
    Quote Originally Posted by Umai Naa!! View Post
    I figured that but am somewhat lacking articulation skills today. Thanks for the better explanation.
    Charming looking stuff
    Oct 2010
    The 1.4 definitely does not have two sets of injectors. The upper engine cleaner is to stop carbon building up, rather than trying to treat it after its happened. Once warranty is up, I'll fit a catch can and see what else I can do in a proactive way.
    You could just leave the car, and pay the 5-700 for walnut blasting after 80k or so if you want.
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
    Jan 2012
    AFAIK only the MK3 TSI engines have 8 injectors. My (MK2 Octy RS) TSI has only 4.
    Looking at that jar, I think ill be installing a catch can also, cant hurt even if you never need it!
    Erskineville, NSW
    That's how I figured it. I had 2 people that told me they did nothing but I got a proper kit for about half the new price. Couldn't go too wrong with that.
    Did I ever post the borescope videos of my #2 & #3 inlets before & after chemical cleaning?
    Oct 2010
    No. There seems to be lots of debate about it though. My experience was with an extremely carboned bike. When I started it after treatment, it blew almost a cup of carbon out the exhaust. It was really bad beforehand though
    Jan 2012
    I had 2 people that told me they did nothing .....
    probably the same people that don't perform mods that you cant really see
    Erskineville, NSW
    That's true. I think one of them has a remap & nothing else. The other has no mods & constantly worries about inlet carbon build-up.
    Cheapy $20 borescope videos of Inlets 2 & 3 before & after a chemical clean.
    Cyl 2 before & after
    Cyl 3 before & after
