Results 11 to 20 of 32
Thread: My speedometer is +5kms out
    Pacific Paradise QLD
    There is now no requirement to have an odometer.
    Dont think thats true Brad From here says they do Vehicle Standard (Australian Design Rule 18/02 - Instrumentation) 2006
    L series are motor bikes etc Cars are M series
    18.5. SPEEDOMETERS AND ODOMETERS (ALL VEHICLES)
    18.5.1. Speedometers
    18.5.1.1. Unless otherwise ‘Approved’, every vehicle must be fitted with a speedometer which must:
    18.5.1.1.1. indicate vehicle speed only in kilometres per hour; and
    18.5.1.1.2. indicate the actual vehicle speed, for all speeds above 40 km/h, to an accuracy of ± 10 per cent.
    18.5.1.2. The speedometer must be installed so that its indication is readily visible to the driver when seated in the normal driving position.
    18.5.2. Odometers
    18.5.2.1. Every vehicle other than LA, LB and LEM group vehicles must be fitted with an odometer which must:
    18.5.2.1.1. indicate distance travelled in one kilometre units (or less) at least from 1 to 600,000 kilometres (for MA, MB and MC category vehicles) and from 1 to 999,999 kilometres for all other category vehicles; and
    18.5.2.1.2. indicate the actual distance travelled by the vehicle to an accuracy of ± 4 per cent.
    18.5.2.2. Every vehicle of category LC, LD and LEM must be fitted with an odometer which must:
    18.5.2.2.1. indicate distance travelled in one kilometre units from 1 to 99,999 kilometres; and
    18.5.2.2.2. indicate the actual distance travelled by the vehicle to an accuracy of ± 4 per cent.
    Erskineville, NSW
    I thought it odd but figured a motoring body such as the RACQ would check their facts before publishing on the interwebs.
    edit: That ADR is from 2006? The RACQ thing says "from 2007". Would that be pertinant?
    I think your right though - I haven't heard of a motor car without an odometer.
    Jul 2014
    My current mk3 over-reads 4kph over at 60 and 8kph at 110.
    My old mk2 over-read by 6kph at 60 and 10kph at 110.
    Odometers for both within 1% with new tyres. 15inch on the mk2 and 17inch on the mk3.
    Worst car was a Hyundai Santa Fe mk1 which needed 124kph on the dial for 110 and the odo was 6% out. Which meant the already abysmal fuel consumption was even worse than initial estimates.
    Jan 2010
    Bathurst, NSW
    My mk2 VRS was out by 3ks at 100km/h, 4ks out at 110km. Always seemed weird setting the cruise to 115km/h on the freeway knowing you were still sitting on the limit. Ok-Ok - I might have usually set it to 120 knowing its unlikely I'd be pulled over in NSW for being 5 over
    Jul 2014
    Quote Originally Posted by bobski View Post
    Sigh, those were the days. I would not try it now
    Erskineville, NSW
    The vRs has the smallest speedo error because it has the biggest diameter tyre (225/40r1. 637mm
    The 225/45r17 option is 0.4% smaller diameter. 634mm
    The 205/55r16 is 0.8% smaller 631mm
    It doesn't sound like much but it makes a km or 2 difference between each size
    Who is messing with my profile?
    Speaking of Odometers, I've never had one correlate with those 5km road markets used to check your odometer. I always seem to run 100m to 200m past the last marker before 5km is added.
    Erskineville, NSW
    when my speedo was 10% over and I had 205/55r16 I'd be at 5.3km at the 5km mark. Nice for Skoda service as it meant the 15k service was happening at 14,200km. It doesn't sound like much but it means the services come up a couple of weeks early. By the time you get to 150,000km you're half a service in front.
    With the 225/50r17 at the 5km mark I'm at 4.8km so I've offset the inaccuracy.
    I'm about to go to 225/40r18 - they'll be pretty close with the odo.
    Dec 2012
    Sutherland Shire, Sydney
    I was wondering why am I one of the few with decent speedo/odo accuracy - but I am running the above tyres
    Erskineville, NSW
    Quote Originally Posted by Martin View Post
    Going to 225/40r18 will make my odo more accurate but stuff up my speedo. Hopefully I'll be able to adjust it with VCDS.
    I was aiming to go with 235/45r17 this tyre change but some 2nd hand 18" wheels & tyres came up at the right price so i thought I'd give them a try - I've had every other size.
