Results 21 to 30 of 32
Thread: My speedometer is +5kms out
  1. #21
    Jul 2014
    I like the odo to be accurate as it just makes true fuel consumption figures more easy to calculate.
    Once I know what the speedo variation is then I automatically allow for it when driving. Just have to watch my speed when I drive another car though.
    Now that most people have got GPS in car or on phone I think that more people drive at the real speed limit than they used to, and this is good.
  2. #22
    Feb 2014
    Geelong, Victoria
    I guessed my speedo would be out, as most other vehicles are continually overtaking me. I ran a test using a mobile phone GPS, dash cam GPS, and our local Mr Plod (a good country copper) to test the accuracy of the speedo.
    SPEEDO 60 GPS PHONE 57 GPS DASHCAM 56 LASER Nil Reading
    SPEEDO 80 GPS PHONE 78 GPS DASHCAM 76 LASER 75
    SPEEDO 100 GPS PHONE 97 GPS DASHCAM 96 LASER 95
    So I will drive 3 kph over the speedo, and hopefully it will satisfy most of the tailgater out there.
    MY13 VRS Octavia Wagon, 2.0 TSI, DSG. Platin Grey
  3. #23
    Jul 2014
    Nice to know the Lasers are accurate and the display is possibly rounded down and not up.
  4. #24
    Erskineville, NSW
    Fourwinds: If you know somebody with VCDS you might be able to tighten up the accuracy by modifying the distance impulse number.
    This uses the impulses from the ABS (48 per wheel rotation) and the programmed diameter of the tyre to derive the vehicle speed. If the programmed diameter is different from the actual diameter then the speedo will be more inaccurate than it needs to be.
    MB202 is the tyre circumferance. The DIN is the popup number in VCDS.
    Coding digit: 1
    DIN*: 22188
    MB 201: 22188
    MB 202: 1938mm
    Coding digit: 2
    DIN*: 22076
    MB 201: 22076
    MB 202: 1948mm
    Coding digit: 3
    DIN*: 21960
    MB 201: 21960
    MB 202: 1958mm
    Coding digit: 4
    DIN*: 21848
    MB 201: 20660
    MB 202: 2081mm
    Coding digit: 5
    DIN*: 22304
    MB 201: 22304
    MB 202: 1928mm
    Coding digit: 6
    DIN*: 22420
    MB 201: 22420
    MB 202: 1918mm
    Coding digit: 7
    DIN*: 22532
    MB 201: 22532
    MB 202: 1908mm
  5. #25
    Feb 2014
    Geelong, Victoria
    Thanks for the info Brad.
    I have Ross Tech VCDS cable and only ever used it to check for faults and to change the fog lights to come on when turning. I still learning and a bit hesitant to change any thing as I might stuff it up. On my next trip up to Greta, I might have to go via your place
  6. #26
    Feb 2015
    Springvale, Victoria.
    Is it reading 5km at both 40kph & 100kph? That's odd because usually it's a percentage out.
    Well I finally remembered to check and, you're right, it is a percentage. At 60kph it's 4km out. I'm not a real fan of having a tail so I'll stick to the GPS readings for now.
  7. #27
    Melbourne, Vic
    Quote Originally Posted by rakehell View Post
    I drove a lot this weekend and noticed that my speedo is consistently reading 5km over my actual speed - according to my Garmin GPS and two "check your speed" gates.
    Has anyone else experienced this? Is it something that built in or could there be another cause?
    I wouldnt be using the check your speed gates for anything.
    Drivers in Vic have still had to pay for fines when the gates said 100 and they were done for 105. The law says the gates are 'indicative' of your speed and not to be used to advise of actual speed. GPS on the other hand should be the most accurate. My A4 was 8km/h out compared to GPS. RS is about 6. And noticeably, the needle on the dial reads higher than the digital on the MFD.
    2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
    2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
    2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
    2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
  8. #28
    Gosford Central Coast NSW
    All vag group cars seem to be 8-10% out. Its normal. It stops you getting booked and improves your fuel economy.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  9. #29
    Erskineville, NSW
    That might have worked 10 years back but if you know it's wrong because you've checked it with GPS & compensate then there's no point having an excessive variance. It's like people that try and get to meetings on time by setting there watch forward 5-10 minutes. It's a pointless exercise.
  10. #30
    Not if you haven't checked it. And not if your wife did it without telling you.
    '99 A4 Quattro 1.8T
