Results 1 to 5 of 5
Thread: My RS Cargo Pocket Fibreglass SUB Build (lots of pics)
    Jul 2013
    Caulfield, VIC
    Hey guys,
    The title speaks for iteself. I wanted to shove a sub in boot of my Octy estate and wanted it looking pretty stealth, sitting flush and fairly inconspicuous to the eys of theives. I also needed it out of the way for my bi-weekly shoving of mountain bikes in and out.
    I gathered that the small inner pocket in the cargo bay was ok but COULD be bigger so I decided to use the space slightly higher around it, running in a straightish line from the wheel guards to the boot lip. I wanted to do it properly and maximise the air volume, all the while keeping the carpet in the car and leaving it stock so its right for sale later. So I decided to make a fibreglass sub box. I didn't have any previous knowledge of working with this material, but I found it fairly simple, and quick to get a hang of. Its all experimentation for the first few layers, then it starts getting quicker. You are always working with a time limit where the resin dries, and it makes the job at hand fun and challenging! If you're thinking of doing the same job it does take a massive time commitment. This one was roughly 25-30 hours.
    Now I'm not going to make a how-to, as there are plenty of other instructables on the net, but I'd like to show what can be done in our cars So here are the pics!
    The victim
    The materials- Ended up needed more resin and catalyst but not more mat
    Cutting up the mat- 300g sheets
    Mixing resin- it turns from blue to green to yellow so you know when its drying up
    Cut it up in to different sized pieces to lay over
    First layer
    3-4 layers in and it was JUST strong enough to take out. Needed to put my feet on the wheel well and use two hands to rip it off without damage. Dont know how without damage though lol.
    Super glue in the mdf sub ring to the angle and height and place you want it. I didn't use an inset ring for mine
    Fibreglass support around the legs, no one else did this but I did because my sub face is large and fibreglass is stronger when round, I felt it needed extra support and it couldn't hurt.
    After about 6 layers, and lots of sanding and fitting, on goes the pantyhose. MAX STRETCH and awkward consultations with girls in supermarkets about the maximum hip size available...................................
    First layer on the pantyhose
    I wanted it plenty round to look cool
    Test fitting
    Decided to put dowells in the corners and ****loads of resin, and let it dry on a slant. Used small downls like this 4mm then big 10mm dowells on top (not pictured). I did this because I thought the air would trap in the corners and try to blast the case open...
    Getting to keen and testing the sound!
    Got the amp installed. Still havn't hid that cable and strap.
    More in next post
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
    Jul 2013
    Caulfield, VIC
    Life inside a sub
    Switched to a different batch of resin and it had white pigment in it. It was ****loads cheaper, but so much harder to use. You dont get to see it changer color as it hardens, and you cant see the bubbles to press out!!!! BAD! Oh well.. I was getting good by this stage.
    Lots of sanding, fitting, testing, resanding going on here. Pain in the
    bum.
    Ended up with about 5-6mm of fibreglass on top of the mdf, ended up
    sanding that down to make the sub sit in lower, then added resin in the
    corners under the mdf ring
    Liquid nails. Most people use spray adhesive but I couldn't wait and I reckon its crap.
    Done the carpet!
    Taping up the bottom to protect interior carpet
    Test fit. Yay! Looks awesome. It doesn't sit as flush as it could
    because I didn't leave space for the carpet. DOH!! Might fix it one day
    Wasn't liking the sound so I decided to polyfil it. Also decided to
    spray paint the inside to prevent loose fibres getting in to the voice
    coil
    I also had to drill a hole in the side to run the speaker wire through,
    then plug it airtight with roofing filler. I then bolted the sub to the
    carpet and installed it back in to the hole. Didn't take pics of this
    though.
    Last job was to do some soundproofing: Lots of Dynamat type stuff for
    absorbing vibration, then MLV.
    Doing some Dynamating
    Mass loaded vinyl over the top!
    Under the seats as well as in the corners. Some other parts done to and
    not pictured
    So there we are! All done. Already coming up with many ideas for the
    versatile material. Definately eye opening and beginner friendly!
    If anyone has done something similar please post here!
    My RS build thread
    Bowral, NSW
    This is awesome!
    Wanna make me a roof console?
    Need somewhere to put switches!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Jan 2013
    Quote Originally Posted by Mysticality View Post
    This is awesome!
    You, my friend, need a 3D printer.
    Nov 2010
    NSW
    that's impressive mate, well done.
    2012 Yeti 77TSI, Candy White
    ydad.com.au: musings of a dad growing up - the blog.
    cbay.com.au: photography, video, design - creations.
