Alright guys, to settle this I finally decided to start my full carbon clean at 1.30am. I thought you know what, it cant be to bad. I should finished by 7.30-8.30...... Bring on 1.30am to start it up!
I'm sooo happy I did the clean. I've been having a number of issues since tuning included blue smoke, rough idles, and hesitations. I'll see if this has sorted these problems in the coming days once the ECU re-learns. For anyone thats done more than 50,000km I'd recommended this 100%. I did mine at 120,000 and you could tell, but to be honest it looks similar to a lot of others I've seen before.
For anyone thinking that the Subaru or other foaming cleaners will work instead of a manifold-off clean, it JUST WONT. After all the km's this stuff is heat-baked on. I had to use a scribe/pick, and wire brushes on the valves, inlets, and throttle plates. Then I had to spray, soak, scrub, mop up, blow dry, pick/scribe, and repeat over ten times per valve, with heavy degreasers. Each valve took roughly an hour to clean. However, you may use the Subaru or other cleaning process AFTER this process or on new cars every 5-10,000km to help avoid build-up IMO. The factory seal gasket was in good nic, so like others, I re-used.
If you are doing a method of cleaning with water, or even the same method as me, you have to be careful with the valves. On mine, 3 of the valves only were closed. I had to wait till they were done cleaning, put it in first and roll the car forward to close the last valve. But lots of degreaser and particles fell in to the cylinder even though it was only open a couple millimeters. So it took ages turning over to start.
Heres so pictures of the process.
A lot of other's DIY's didn't show cleaning of this. I didn't work out how to remove the whole flap plate, but starting from the right, most of it flexes out, so you can clean 90% of them. There is heavy build up here and you need a scribe or wire brush to remove it.
Throttle plates look healthy aye
First sight of the valves. Lets get a better look
The injectors on the manifold had build up around the port but weren't ridiculous
But injectors on 1 and 4 were atrocious. Completely caked on. Had to scribe off the junk
Here's the results after the clean
