Terrific work Mike, glad you jumped on that.
I wish it was that simple, and I've used a few more expensive cleaning products before in there, but from looking at the pictures and reading about the build up on the Audizine carbon build up megathread, I believe any outside measure wont do a good enough job- far from.
Today I received the Kufatec E-MFA add-on second hand from someone on here. It gives extra info from the cars MFD such as fuel in liters, boost (although for some reason doesnt work with petrol cars), voltages, water and coolant temps, and also logs 0-100 times and a few more things. And you can play that old Nokia game, Snake
Didn't take to long to install, its plug and play. But I had to spend over an hour move things around and zip tying. Then I had to cut out the back part of the head unit cage to make space for wires (it already had to be jammed in because of the DNS-810 being deep. I also had to cut a section out to the side to fit the Kufatec... Looks so dodgy. I'm lucky I didn't snag a wire...
Cut the end
Next, you can see the section on the left I chopped out...
Cool! Definitely need to play with this more.
I also made the access better to my iPod and cable
Then I made a nice hole to access the USB drive port
Now does anyone know the difference between these cheap ****7ers and the proper ones that Dub Addiction sells???
www.TheRapidWrench.Melbourne
The convenient, professional and affordable mobile bicycle mechanic that comes to you!
My RS build thread
Driver Motorsport Tuned | Melbourne Car Meets | Insta: @VLNTVADERR
I don't know what it is?
catch can I believe.
Mike, have you had a borescope into your inlet to see how it looks? They are pretty cheap at Aliexpress.
I've water sprayed mine just before the last 2 oil changes & it's definately more sprightly afterwards. The first one was about a litre of straight water (because I've run straight water injection previously). Last time was a litre of 50:50 water:turps.
I can see water injection in your future.
re: the catch can. I reckon you'd be better off looking for a cheap 2nd hand name brand unit. Maybe from one of the US forums?
The propper Catch cans (42DD) have a filter/gause inside that catches more of the vaporised oil in the air passing through it. SO it Catches more basically.
Also has the option of a tap on the bottom for easy emptying and come as a kit with all the bits to install on a VW var
Brad, how does a liter of water and girls not find it's way in to the pistons? How do you drain it out? Also, the process has to be good enough to clean the valves as well and you have to be able to crank the motor to get to the valves
Cool that's what I was looking to hear. I need a proper vw kit anyway to get the Pcv plate with it. There's hardly any way I could fabricate mounts on to the current bsh pcv to make it neat enough.
My RS build thread
Mike
Basically, you get the engine up to NOT and then remove the air temp sensor from the front of the inlet manifold. Start the car (it will run like a hairy goat) & bring the rpm up to 2500rpm (put a stick on the throttle pedal & jam it into the seat).
You them get a garden sprayer set on a fine mist with 1-2 litres of water or a water/metho/turps (depending on what part of the world you are it's sometimes called mineral spirits or white spirits)/ turco (I thaink that's been banned now) / carb cleaner / light hydrocarbon chemical / methyl chloride, methanol, methylene dichloride paint stripper (same as carby cleaner) - As long as it isn't caustic as caustic soda (oven cleaner) will eat up the aluminium.
Put the spray nozzle into the air temp port (the revs will shoot up to 6k or so because you no longer have an air leak) and then start spraying the water so the revs drop back to about 2500rpm. If the engine starts to stuble you stop spraying. The venturi effect will actually try & suck the water out of the sprayer.
The hot engine turns the water into steam & it goes straight out the exhaust pipe. The steam cleans out the carbon.
You could try soaking in Simple Green first or mixing Simple Green with the water.
This guy is a bit heavy on water for my liking
This guy basically has it right but geez he rambles
