Page 8 of 16 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 159
Thread: MountainBikeMike's Skodaru
  1. #71
    Dec 2012
    Gold Coast, QLD
    Quote Originally Posted by MountainBikeMike View Post
    Hey guys, bit of an update. After 10 hours of swearing and hurting, I'd finally done the timing belt change myself
    When I bought the car dad and I looked up the specs for its change, and were certain it had to be done at 160-180k km. That ended up being for Europe, so we were wrong. I panicked, having already driven 118k km, it was almost 20,000km overdue. So I got to it straight away before the Winton FunDay.
    For anyone else game enough to save the dough and learn a sh17load about their engine: GLHF!
    I don't think I could have pulled that off without Dad and a lot more swearing - Well Done - and congrats to the missus for not divorcing you in the process. Awesome thread
    NOW: 2018 MY19 Kodiaq Luxury and Tech Packs: 132kW Petrol 7DSG Sunroof and Ivory Leather
    HISTORY: 2012 Fabia RS (FOR SALE) ; 2013 Fabia RS (SOLD); 2015 Octavia RS 135TDI (SOLD)
  2. #72
    My Dad and I came to the conclusion a long time ago when I was 16 and went to work on my first car, that we should never work on a car together again and that from now on, anything bigger or complicated is left to Mechanics to curse at and I'll just do the small stuff. It has worked for us ever since!
  3. #73
    Well done on the timing belt change Mike - big job for someone who has never done it before. Kudos.
  4. #74
    Dec 2012
    Sutherland Shire, Sydney
    Great effort
    (I also have my 350Z in pieces - learning lots)
    Love the photo of the lady in the tyres
    Matti's wheels actually look good from a distance in those photos
  5. #75
    Jul 2013
    Caulfield, VIC
    So today is another mod day. I finally got around to installing the $15 repco boost guage I've had sitting around for about 4 months. Back when I got it I made a fibreglass/carbon bay for it, which was cool as, but it didn't turn out that well because it was way to sticky with the resin, and also ended up with a bad fit.
    Anyway I found inspiration from Jon doing a few installs for his mate, so I finally got to it. I might make another fibreglass one again one day, but for now this one sits nicely in the groove under the tacho.
    So firstly I connected the vacuum hose to the other port where the diverter valve blow-back connects to the intake manifold, and routed it under the intake, and behind the battery, through the firewall (drilled its own hole there so it never gets pinched), and up to the top-dash. Will get an engine pic tomorrow.
    I sat the sender unit here.
    Opened this little part
    Carefully drilled a little hole here and fed the wires from the gauge that I headshrinked in black through.
    And drilled here to make some extra clearance for the cables. This is the section underneath the window that covers the top of the steering column.
    Then I soldered the sender and gauge red power wires on to the amp-on wire that I just pinch in to one of the fuse slots.
    I also wrapped the gauge back and sides in black tape to protect the window from scratching, and dull down the flashy appearance a bit. I stuck the gauge down with 3M clear sticky gel stuff, the stuff that comes on various packaging, it sticks well and peels easily. Here's what the finished job looks like.
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
  6. #76
    Looks sick as, Mike. Very different from the norm.
  7. #77
    Jul 2013
    Caulfield, VIC
    Quote Originally Posted by Deadpool View Post
    The added bonus is it covers any possible CEL woo
    Sent from my HTC One X using Tapatalk
    My RS build thread
  8. #78
    Bowral, NSW
    I have a feeling there are two blue vRS wagons here that will never stop being modded ;p
    Nice work - love it!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  9. #79
    Jul 2013
    Caulfield, VIC
    Quote Originally Posted by Mysticality View Post
    You have good feels. And that muffler of yours is going on my car tomorrow.. if I can weld upside down...
    My RS build thread
  10. #80
    Bowral, NSW
    It arrived? Awesome.
    Pics when done
    The tip is almost identical to the existing vRS tip, just larger and meaner
