Page 15 of 16 FirstFirst ... 513141516 LastLast
Results 141 to 150 of 159
Thread: MountainBikeMike's Skodaru
  1. #141
    Jul 2013
    Caulfield, VIC
    It looks the same. I have no eye for detail at times.
    Should have gone to specsavers
    Quote Originally Posted by NOO63N View Post
    I like it! Might steal your boot light idea. I go fishing from time to time, the light would be a massive blessing! I'm thinking stealth install with a switch somewhere in the boot...
    It only looks like that as I dont have the rear panel on the hatch. Bloody clips dont line up its so hard to get back on
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
  2. #142
    Jan 2013
    Can you post what it looks like when it's back on? Close ups of the set up pwease!
  3. #143
    Jul 2013
    Caulfield, VIC
    Update time:
    My mobile bicycle servicing business is LIVE Exciting times. Info can be found on the website in my signature!
    So I'm trying to get the car a little more ready with an 2x2m awning. $129 on eBay. Its a little fiddly to open and close with one person, but I got better at it. Only about 90-120 seconds to open or close.
    First I had it mounted on the end of the racks like this
    Since they are designed for high 4wd's it was kinda low. I ended up fixing on some 350mm fence hinges to the rack to achieve a bunch of things.
    1. It doesn't sit at the side looked retarded
    2. It sits in the middle so the 11kg doesn't trying and weigh the car over the edge of a cliff
    3. It gets me the extra head height so it actually does the job properly
    4. Rain will land on top of the car, not go straight through the doors to the seats lol
    Result (notice the temporary marketing magnets before I get the car wrapped):
    My RS build thread
  4. #144
    May 2012
    O wow. That awning mount is great! I thought getting an awning in the past but could not get past the height issue ...
  5. #145
    Mar 2014
    Melbourne, Victoria
    That's awesome mate, congratulations on the new venture! Makes me want to get back to my mountain biking days... Sigh!
    Quote Originally Posted by MountainBikeMike View Post
    Update time:
    Walking Contradiction...
    MY15 Skoda Octavia vRS 162 Race Blue Combi
  6. #146
    Nice one mate - good luck with the business.
  7. #147
    Bowral, NSW
    Whooo! Love it!!
    Kinda want an awning like that for camping... hmm.....
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  8. #148
    Jul 2013
    Caulfield, VIC
    Hi guys,
    I'm selling the drawers setup that I made for my business. I only used it for a month before deciding that I needed a toolbox setup instead. Its essentially as new, if you call it that since it is custom made. Would suit a tradesman etc, fairly heavy duty.
    -It has a locking mechanism on the front that is easy to grip with the fingers and is spring loaded. It unlocks both drawers at once and stops them opening in transit.
    -The drawers have a gap underneath them to the floor of 16cm, which is the depth from the opening to the floor of my Octavia. This means you can store things underneath by lifting up the front of the drawers 30 degrees. It is designed like an arrow at the back to allow this, and to make it easier to pivot! Means you can also store things underneath out of view. You could fit gas struts to it if you wanted to.
    -Has lots of holes cut out underneath to greatly reduce weight while retaining stiffness. It does however need to be braced to the car at each side. This doesn't mean actually attached to the car, just making contact with the wheel wells so it doesnt bend back and forth on corners when fully loaded!
    Dimensions:
    Width 975mm
    Depth at top 725mm
    Depth to arrow point 972mm
    Depth at bottom 870mm
    Height 420mm
    Height from floor to bottom of drawers 160mm
    -Cost of making it was:
    $60 for the 12mm and 16mm mdf
    $20 for the hard wearing soft rubber on the top
    $56 for the 4 drawer sliders
    $10 spray paint
    Assorted screws
    About 10-12 hours hacking away
    Asking price $150 FIRM, so pretty much just covering the cost of making it.
    [url=https://flic.kr/p/nUyiJ1]
    [url=https://flic.kr/p/q5cscS]
    My RS build thread
  9. #149
    You must be a handy man to have around the house, that's an awesome custom setup there!
  10. #150
    Aug 2013
    So tonight I finished a couple of quick little 'convenience' mods that I've had in mind since forever. I cannot believe I waited for this long and how quick they were to do, with these little lights sitting in the draw for months...
    So the first one is something I've wanted to do for about two years - since half way through owning my previous car... I finally did it tonight after fighting the mental block, and it took me an hour.... See I've always found it, 'not difficult' but not timely to reverse park in the dark at night. My crewman had a very tall rear and even after 50mm lowering the tail lights were still so high so no light made it to the curb. My Octy has the problem that the windows are so tinted I can hardly see through the mirror to the curb :p .
    So the solution was these $2 screw type lights from AliExpress! These are round and have a thread behind them with a locking collar so you can mount them inside a panel. I ran them from the rear bumper near the wheel, up through the one way exit-air vent, up the the rear light panel, and ta-da! Heaps easier to see that curb, take less time parking, less 'guessing', and less gutter rash!
    Ocky straps everywhere!!! Handy to hold stuff out of the way instead of removing them :p
    Where I soldered on to the reverse light so it only comes on when in reverse
    See where I ran the wire through the circuit board and the air vent?
    Neat little inconspicuous circle. I could have gone lower with it, but I wanted it clear of mud
    Decent output! This is with the car jacked up and wheels off the ground... And the curb non-existant. It will seem brighter ones those two factors are opposite
    I will also get a nicer picture tomorrow night with the dslr of how it looks like through the tint and mirror inside the car.
    Thanks for this idea mountainbikemike - i did the same thing on my polo.
    I had big problems trying to see out my tint at night and constantly hit my back tyre on gutters.
    I dont anymore!!
    I Sell Nissans Skodas.
    IT'S HEREEEEE 18' Skoda Octavia 110tsi Manual Hatch | Race Blue | Tech Pack | Luxury Pack | Panoramic Roof | Turini Alloys | Various VCDS Tweaks | RS Spoiler | Mars Bar Holder
    R.I.P; 13' VW Polo 77tsi Comfortline Manual | Candy White | Sport Pack | Pioneer AVH X3800DAB + Clarion Bass Pack
