Results 11 to 20 of 33
Thread: MkV GTI shocks and springs on Octy Wagon?
    Erskineville, NSW
    I think you are right - 90tsi is 50mm. Get the calipers out & check.
    Bowral, NSW
    Yeah. I'd go ahead and try to stick to Skoda bits... At least until they aren't enough.
    Keeps the dealership happier.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Jul 2010
    Quote Originally Posted by cbay View Post
    Another question... would darkshadow's vrs liftback springs match my 1.4tsi octavia wagon?
    they will fit no doubt.
    the question though, and my concern would b the spring load rating.
    the vrs is heavier than the 1.4tsi, and as such the springs r designed to handle more load.
    if u put it on the 1.4tsi, it will probably remain at the same height cause it ain't heavy enough to weigh down the springs?
    or maybe it will actually drop by 12-15mm?
    dunno.
    happy for u to try it out. if its all good & ur happy with it, u can pay me - otherwise just return the springs.
    i'm usually up in sydney once a month. where abouts r u in "nsw"?
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Gosford Central Coast NSW
    I put 2.0TFSI VRS springs in my 1.9TDI and the front ended up about 5mm higher than stock.... like I said in an earlier post - theres a big difference in the tare axle loads for all the different octavias, so the rates are all quite different.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jul 2010
    thought just as much.
    i did some number crunching, and it turns out the 147tsi liftback is "lightweight" in comparison to the other octavia models!!
    the 103tdi takes the belt for heavy weight champion.
    weird though, as it contradicts the weight loading for the springs & the tyres aswell..........
    Bowral, NSW
    Yay! Mine's not THAT heavy... XD
    heres my info...
    118kw 1.8tfsi liftback 1325 combi 1340 (6 speed man), 1360/1375 DSG
    147kw 2.0tfsi liftback 1400 combi 1415 (6 speed man), 1435/1450 DSG
    77kw 1.9tdi liftback 1310 combi 1325 (5 speed man), 1350/1365 DSG
    103kw 2.0tdi lifttback 1335 combi 1350 (6 speed man), 1370/1385 DSG
    125kw 2.0tdi liftback 1430 combi 1445, 1465/1480 DSG
    My info seems very different from yours Darkshadow
    Unfortunately Mysticality, i reckon you have the heavyweight
    Logically - the 125TDI is the monster engine - has all the diesel weight with the larger turbo and more complex emissions system. The 147 petrol isnt far behind because it too is a complex engine with plenty of valves and big manifolds etc. Add to that the luxury models having all the extra weight of climatronic and bigger wheels, even the weight of nice upholsery if you have leather (is that an option?) and things get heavy.
    According to my info, if you want a lightweigh octy, you should have gone for one ofthe low power european models - like the 1.4l 59kw petrol with 5 speed manual - 1230 liftback and 1245 for the combi.
    '99 A4 Quattro 1.8T
    Erskineville, NSW
    weird how all that extra air space in the cylinders weighs so much.......
    The difference in bore between the 2.0 and the 1.9 tdi's is pretty small (they have the same stroke) and each cylinder is only about 22.5cc bigger.... thats less than 200grams difference if the block was exaclty the same in all other respects
    Whereas, the 8V head is a fair bit more compact than the 16V and weighs a lot less. The biggest weight differences are in the gearboxes though.
    '99 A4 Quattro 1.8T
    Erskineville, NSW
    how do you know that the 22.5cc of air weighs 200grams?........
