Update,
Found an appropriate DMF, information not well documented anywhere but found a wrecker that was selling the exact same gearbox with flywheel that had the 8 bolt configuration and was able to zoom in and get the part number I needed ([COLOR=rgb(var(--color-foreground))]06K105266A)[/COLOR]
Finally got the engine in the car, many lessons learnt;
140kw tdi has an 8 bolt crank vs 6 bolt crank on 135kw, flywheel that matches the gearbox is the same as on the Golf GTI or Audi S4 with the petrol engine and dq250 DSG (weight of DMF was same as the original one in the skoda)
Turbo inlet on the 140KW is larger in diameter than on the 135kw engine as a result the inlet plumbing did not directly fit, however the ID of the inlet hose and the ID of the turbo inlet are the same so I used some Silicone inlet piping as an external sleeve to join these which made these two pipes join without a step change in diameter as was the case with the original setup (no step change= less turbulence potentially allowing more air in).
New engine running and can definitely notice when the turbo spools up where before it was more of a linear progression.
