Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 61
Thread: Mk3 RS 162TSI fuel consumption...
  1. #21
    Oct 2010
    2100/2200 isn't bad. Means the car is still responsive in to gear. To speed for an rs is still ~245 so even taller gearing isn't needed.
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
  2. #22
    Jun 2013
    Gold Coast
    Considering I'm buying a manual RS im very curious to hear from Mk3 RS owners and their long term L/100 figures from their MFD
    maybe post up the transmission, L/100 and % split highway/city cycles?
  3. #23
    Erskineville, NSW
    Mk3 RS & long term is an oxymoron isn't it?
  4. #24
    Jul 2014
    I know you get a great deal of pleasure out of modifying and driving your vehicles and good luck to you.
    I drive at the applicable speed limit on public roads. I may (usually) apply a bit of wellie getting there, and I get there a lot quicker than I did in my diesels. I do not think that a slow take-off from lights is fuel efficient or socially acceptable.
    I am not that good a driver but I do know how to overtake having learnt on sub 1.5 litre British 60's era cars on English B roads and country lanes.
    I reckon I can do a better job of overtaking on my daughters 8 yo 1.3 manual Echo than most Australian drivers in their V6/8 . Why do they tailgate the trucks they want to pass, so they cannot see anything?
    I think that Octavias, whatever flavour, provide pretty much the best of all worlds.
    With most cars it is choose any two of the following a)cheap b)good c)reliable
    The octavia has all three
  5. #25
    Apr 2008
    Western Sydney
    Although im aware that the latest 2.0 TSI engine is more efficient than ever, its also the most powerful ever. Im having a bit of a chuckle about all the talk on economy and efficient driving......you bought the sport model with a turbo engine!!
    Ride the boost and enjoy the power.
    Using fuel is easy, trying to see how far I can get with one tank is a challenge I'm up for.
  6. #26
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by GTR27 View Post
    Sub 2000 would be even better fuel consumption wise. And if you want the car to respond you either remap the ecu or change down a gear....simple. 6th gear should be seen as an overdrive.....not a gear to change into at 65kph!!!!
    And I can't see your point of the 245 comment.......we don't have any roads capable of that speed so it's irrelevant. Out of curiosity, do the Euro's get the same gearbox as us Aussies? With their autobahns, they would most def need a 7 speed manual!!!!
  7. #27
    Oct 2009
    Mitchelton, Qld
    Oh and who drives an RS for fuel economy calculations anyway!!!
  8. #28
    Oct 2010
    245 shows that the car is really capable of higher speeds, so cruising at 110 isn't an issue, regardless of revs.
    Fuel economy isn't solely dictated by revs. Having it closest to peak torque usually give best economy, however torque figures are rated at Max load, full throttle. So peak torque on light engine loads is higher in the rev range, hence the shorter gearing. The gearboxes are set with evenly spaced ratios, because in the real world that's much nicer to drive than a car with one odd moonshot gear. Commodore v8s are a great example of 'overdrive' gearboxes. And 6 th happens to be completely useless under 110, thereby reducing the number of usable gears to 5. Which is what would happen if the ratios were lengthened to accommodate a taller 6th gear. It would just mean one less ratio for most circumstances.
    Someone who only drives on the highway might appreciate it, but 90%+ of drivers don't drive solely on the highway. I'm sure they did a lot of testing to determine the best mix of gearbox ratios/engine combo.
    Edit: I'm sure you might feel it's better for one tall ratio. If it really bugs you, you could get it changed, but it would cost lots. (Either that specific gear, or the diff ratio)
    Edit2: sounds a bit harsh. I'm just trying to get at 'the manufacturer would have done it for a reason. If they could have gotten better economy with a taller gear, they would have done it'
  9. #29
    Glen Waverley, VIC
    Quote Originally Posted by vEnOm_oz View Post
    Would have been driving one for a couple of months now, if not for the dealer fumbling with the order and a DSG turning up instead. Sighhh...
    Mine: Octavia vRS Combi (MY15) | Brilliant Silver | 6MT | 162Kw 350Nm | Tech Pack* | 18" Black Pack | Leather | Sky Port | Ordered Aug 14 | Built Wk 48 2014 | Landed 3/2/2015 | Delivered 20/2/2015
    Hers: MY06 MkV Golf TDI 6DSG | Silver | Stock | RNS510 + Badge RVC Installed.
    Weekender/Project:
    Classic Mini 1972
    Dependant #2: Mk4 2001 GTi
  10. #30
    Apr 2014
    I'm feeling much relieved after reading this thread.
    I'm up to 750kms and my RS is still drinking fuel like a drunken sailor. If I try to be as light footed as I can and leave the car in Economy mode I'm only getting 11l/100kms which was scaring me a bit.
    I'll see how it goes when we get a few more kms on the clock
