![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
jfi2ee
So was driving into work this morning when all of a sudden the oil light came on in the car, pulled over and checked the dipstick oil was pretty low - topped it up and all good now. Only had the service done two months ago (first service) my question is this normal for oil to drop so much straight after a service? I spoke to the dealer who said to keep an eye on it?
Its a MK3 octavia dsg
thanks
When you say "first service" do you mean the 15k/1yr service or the unofficial check they offer at 2000km which doesn't involve an oil change?
These engines use oil when new. Some even use oil right through the ownership experience. It's unusual to get through the first 15k without an issue and then have oil consumption after that.
After the service did you open the bonnet & check all the levels (and the tightness of all the caps)? I know you shouldn't have to but I've found incorrect oil levels & loose caps several times - dealers are pretty hopeless.
