Page 13 of 18 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 172
Thread: MK3 Octavia - List of Defects, Faults and Issues
  1. #121
    Apr 2012
    Upper North Shore,NSW
    Quote Originally Posted by ozgti View Post
    Also on part throttle downhill, it has a hesitation in 3rd. Eg, slow down for a left into a street that points downhill, car shifts to 2nd around the corner, then when you accelerate again, it will hesitate then accelerate in 3rd. It doesn't do this on the flat at the same speed, so I'm hopefully going to rule out turbo lag. It's a 135 tdi.
    Sent from my SM-A8000 using Tapatalk
    It sounds normal for our 6 speed DSG, the DSG programing of the Gen3 is to be blamed, you are going downhill, so the car goes into a lower gear earlier to engine brake for you, and when you accelerate, it choose the most economical gear for you. I don't like it either, so I put it into M when I am not cruising on flats, much better that way.
    Btw, what mode are you running on? Sports? Normal? or ECO?
  2. #122
    Feb 2009
    NSW
    Normal
  3. #123
    Jan 2014
    Narangba, QLD
    Body Flex?
    Hi,
    I am noticing lately that when cornering in an enthusiastic manner that I am hearing some creaking from the drivers door. Is there body flex in the A7 Octavia or does the door just need adjusting?
    Cheers,
    Karl
    MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
  4. #124
    Sep 2009
    Stirling, SA
    Quote Originally Posted by Reichter View Post
    If you've only JUST turn the wipers off, they will stay in the "ready to go" position. But once you haven't used them for a while (forgotten the time frame) or turn the car off, they will go back into the parked position. Pretty sure it's in the manual.
    That's what I was expecting.. What I'm seeing is that they seem stay in that position even after I've turned it off, got out of the car (which it recognises because it turns off the stereo when you open the door), and locked it. I admit though I haven't noticed whether or not they are still like that when I return.
    2007 Golf 2.0 TDI Comfortline DSG/ESP
    MY15.5 Octavia RS Wagon 135TDI, Race Blue, 18" Black Pack, Tech Pack, Comfort Pack, Auto Tailgate, Panoramic Sunroof
  5. #125
    May 2016
    Quote Originally Posted by sillyboy View Post
    I got my RS on January this year, been on ECO everyday, bit currently just change to Normal mode, i feel that at low speed ( exit out of drive way, speed hump) on few occasion, i can feel a slight bang... which got me scared, so i change to normal mode, although i can feel it seems to consume more fuel on normal mode.
    MY16 Octavia VRS, Black Magic
  6. #126
    It will be the door seals, you can either give them a really good clean, as sometimes polish/wax etc get on them. Or you can try gummi pfledge. Our Mk2 creaked its entire life when going in driveways etc, but I did note in the manual it says the door rubbers have a varnish on them to stop ice etc sticking to them and not to coat them. Assume the old one probably did too and many people use Gummi Pfledge on them still.
  7. #127
    I find my car pretty dark when inside, and realised today while trying to update the POIs that there is actually a light in the glovebox, its just not turning on. Is there something obvious I'm missing or did my car come with a DOA glovebox light?
  8. #128
    Anyone getting a squeak when their sunroof is open, halfway or even fully?
    [FONT=Franklin Gothic Medium]Matt
    2015 Skoda Octavia RS | Combi | DSG | Metallic Grey | Tech Pack, Every Option Except Leather |
    Prev: 2012 VW Polo GTI | 5dr | DSG | Reflex Silver | RCD510 |
  9. #129
    Nope but it rattles at the front of it on bad roads when closed. Thats with the screen retracted completely back. I think its the wind deflector bits.
    My glovebox light still isn't coming on so guessing its a DOA from delivery. Trying to work out if I can be stuffed going to the dealer after my tint issues to get it looked at.
  10. #130
    Pacific Paradise QLD
    Quote Originally Posted by woofy View Post
    Might only come on when headlights are on Mine is like that. Doesnt come on in daylight
