Page 16 of 18 FirstFirst ... 61415161718 LastLast
Results 151 to 160 of 172
Thread: MK3 Octavia - List of Defects, Faults and Issues
  1. #151
    Hey guys, have been having a intermittent recurring issue. I can't work out the parameters that cause it to occur and can''t seem to replicate it when I try. Occasionally my Auto Stop/Start will not engage when I am stopped with the brake depressed. It doesn't come up with an error code, however when I check the status in the MDI it says "Engine must be running". The engine is running by the way when this happens. Any thoughts as to what could be the cause? Feel like I don't have enough info to take this to a dealer yet, as they will just check the codes.
    Thanks,
    Vehicle of choice: Skoda Octavia RS Combi (Black Magic)
    Previously: Volkswagen Jetta MY12 118tsi 6spd Manual (written off)
    Reason to get up in the morning: Secondary school teacher
  2. #152
    Sep 2009
    Stirling, SA
    Things like AC, heated seats etc place a demand on the engine. You will also see it restart while you're stopped if the demand is there.
    2007 Golf 2.0 TDI Comfortline DSG/ESP
    MY15.5 Octavia RS Wagon 135TDI, Race Blue, 18" Black Pack, Tech Pack, Comfort Pack, Auto Tailgate, Panoramic Sunroof
  3. #153
    I wouldn't worry about it, there are several conditions that have to be working before it will do it. I thought it was broken from new in my manual car but then found I have to have it in neutral, handbrake on and take my foot off the clutch. 3 things noone ever does at the lights. It also won't kick in first thing if not warmed up and also if the battery needs charging a bit. Unless you are seeing a warning code, don't worry about it.
  4. #154
    Erskineville, NSW
    Wife has stop start on her Honda. No matter how much I drive it, I still hate it.
    to the OP: You probably haven't met all the parameters to stop the engine.
  5. #155
    Pacific Paradise QLD
    Can depend on how hard you have your foot on the brake In my car Foot on hard engine stops Lift it off slightly engine starts but brakes still keep car still. Handy to get away at the lights if you anticipate them by doing so.
    I have found if I dont want it to stop I just brake more gently.
  6. #156
    Apr 2012
    Cherrybrook NSW
    Quote Originally Posted by woofy View Post
    Interesting you need the handbrake on. On holiday in Europe in 2012 I drove a rental Renault Scenic diesel with manual trans. As most rental places these days just give you the keys and wave you off (once you sign off all the paperwork), I wasn't aware it had stop-start until I put it in neutral and took my foot off the clutch at a set of lights somewhere in Munich (where I picked it up). Given that it was the first time in quite a few years that I'd driven a manual, sitting in the wrong side of the car and with a horde of impatient German drivers behind, I was a little panicked... lucky the car had Italian plates on it... As my habit is to push the clutch in to start, the thing sprang into life as soon as I tapped the clutch pedal, so crisis averted! So, all it needed was foot on brake, gear in neutral and clutch out to stop. As soon as the clutch pedal was pressed, and it didn't take much pressure, it started. By the time it was in first, the engine was well and truly ready. I was actually quite impressed by how well it worked. At least there was some immediate control over it with the clutch pedal.
    I find the stop-start in the Skoda (with DSG) kills the engine way too early, almost to the point where it's cut before the car has actually come to a standstill. I haven't found brake pedal pressure to make that much difference and I always try to brake as lightly as possible anyway.
    MY 22 Superb Sportline Wagon. Moon White.
    1985 BMW K100RS in JPS racing livery
    2019 BMW R1250GS Exclusive
  7. #157
    Quote Originally Posted by k_rider View Post
    In the interest of comparison, I find my my experience to be quite the opposite, in my experience the activation point for my Octavia is perfect and easy to control when slowing down / stopping. If anything I find the restart occasionally to frenetic, the slightest shift of foot on the brake pedal can restart the motor. But all in all, I love the system, except for this issue about the "engine must be running message", however as said above, if there is no error code, I won't worry about it too much.
  8. #158
    It kicks in pretty quick when you touch the clutch. I was thinking of disabling it with VCDS, but it pretty much only comes on when I don't care so not fussed. It's pretty useless in the manual to be honest they may as well not have bothered. On another note, did others see that Skoda are doing a recall on 2016 built Octys for defective child door locks, letter in the mail coming apparently.
  9. #159
    Jan 2007
    brisbane QLD
    ours also doesn't activate sometimes for up to a day, even after cruising on the highway for a while. But as start-stop systems go I think it's pretty refined, especially the manual. However it can activate too soon sometimes long before we become stationary. I think it's a nice feature, but these engines run so lean at idle, you have to wonder how much fuel are you really saving!
    Main Dub:
    2010 Crafter Hanover Bus
    1956 Type 1
    2015 vRS wagon black on black
  10. #160
    Waiting to take my RS in to see why the glass roof is rattling when it's open....
    [FONT=Franklin Gothic Medium]Matt
    2015 Skoda Octavia RS | Combi | DSG | Metallic Grey | Tech Pack, Every Option Except Leather |
    Prev: 2012 VW Polo GTI | 5dr | DSG | Reflex Silver | RCD510 |
