Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: MK3 Brake effectiveness
    Nov 2012
    Canberra
    Hi John, Are you still selling the yellow demon? Probably should catch up soon for a coffee.
    Cheer
    Jas
    Skoda Octavia Vrs 2008 TFSI Race Blue
    | CC Phase 2 tune | BSH PCV revamp | DRL's | HID | LED's | 35% Tints | Towbar |es1099 HU | Rev. Camera | R8 Coils | Brisk LSG Plugs | Adams slotted Fr Rotors | Torque arm insert | 3" Down Pipe | High flow cat |GFB DV+ | VM Shifter Bushes |
    Bowral, NSW
    Every time I drive a Mk3, I'm amazed at how good the stock brakes are. If I owned one, I'd say probably the best bang-for-buck upgrade would be two-piece rotors on the standard caliper. I don't know what the standard MQB 340mm rotor weighs, but the PQ35 345mm (Mk5 R32/Mk6R/S3) rotor is 12.5kg! Big weight savings to be had.
    If you're adamant about doing a big brake kit though, be sure to grab a kit designed for a Mk7 Golf R, as your front brakes and the 7R's are the same part.
    (Also, post pics! )
    These discs on my Mk2 are 15mm larger than the Mk3 vRS stock brakes.
    MK3 Brake effectiveness-wp_20170203_15_15_18_pro_li-jpg
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Feb 2015
    If your looking at upgrading I think this would be your best choice other than going a big brake kit...
    https://shopdap.com/store/make-model...ds-rotors.html
    DBA also makes a 5000 series too I think - DBA5 2830.1
    Bowral, NSW
    Quote Originally Posted by hally83 View Post
    http://www.dba.com.au/dba-part-finde...id=DBA52830.1S
    These would be amazing.
    Feb 2009
    NSW
    Quote Originally Posted by Mysticality View Post
    Just bought a set of these.
    Sent from my SM-G930F using Tapatalk
    Feb 2009
    NSW
    All good and well... But I need the top hats... So just refunded and got the non slotted rotors... One piece with hats!!!
    Dec 2016
    Brisbane Qld
    Took the car on the track last week and was pushing the car hard and braking very hard / late down the front straight into the first corner (spectators said my abs warning tail lights were often flashing) not once during the session did I notice any sort of brake fade, pedal vagueness or he abs kick in
    Lots of dust and a blue tinge to the rotors for a few days after but otherwise faultless
    MY16 Octavia VRS Wagon, DSG, Race blue, Tech pack, Comfort pack, Black Pack, 19's, Sunroof, Electric Tailgate
    Airbox mod, VW Racing Filter, TMD, Elbow, Ramair Pipe, GFB DV+, VCDS mods, Superpro adjustable rear sway bar, Superpro end links, Whiteline front sway bar links, Whiteline LCA bush Kit, Bilstein B14 coilovers, HPA dog bone mount & arm, 42DD oil catch can, Burger wheel spacers, CTS downpipe 200 cel cat, 2,5" exhaust , twin out. Super Skoda eyelids & front splitter, Tuned by BPS 228kw atw, Dsg tune,
