Results 1 to 10 of 17
Thread: Mk 2 vRS Parkers
    Oct 2009
    Mitchelton, Qld
    Mk 2 vRS Parkers
    Hi,
    Anyone out there with a Mk2 vRS could you please confirm or otherwise that the vRS parkers don't actually come on. I understand from reading some of the OS forums that this is because the vRS has DRLs hence parkers are not required?
    I got a bulb failure light come up so checked all the lights and noticed that when I turn the light switch to parkers, no lights come on at all, hence my question above.
    Bowral, NSW
    This is correct. The DRL's dim down and act as parking lights.
    The parkers in the vRS aren't actually wired in.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Feb 2014
    Geelong, Victoria
    Finger trouble Double Post
    MY13 VRS Octavia Wagon, 2.0 TSI, DSG. Platin Grey
    Feb 2014
    Geelong, Victoria
    As Mysticality stated, the DRL's dim down and the rear is light-up like a xmas tree. I normally just flick the blinker up to have the the right side light, if parking for a long period to save on battery drain.
    Edit: When you say "when I turn the light switch to parkers, no lights come on at all" are the rear park light on or not functioning as well? I just pulled a bulb from the rear and all light function (excluding the one pulled). I will ask the obvious, have you checked the fuse (if all park light are not functioning).
    Oct 2009
    Mitchelton, Qld
    Yes the rears work fine. Just no lights on the fronts when I switch to parkers only. I couldn't find the fuse # for the parkers in the manual?
    The bulb warning light message is saying "rear left side light...I understand there's more than one bulb in the rears so I'm assuming one of these has gone whilst the rest are working.
    Bowral, NSW
    Quote Originally Posted by donweather View Post
    Parker/brake is one globe; varies voltage for functions.
    Two T10's handle the outside parking lights.
    Parker/fog is also one globe; varies voltage for functions.
    Turn the parkers on, at night, and just have a look around.
    Also, make sure your DRL's come on as parkers!
    Feb 2014
    Geelong, Victoria
    After posting my response, I decide to check the fuse location and amp rating etc, and the owners manual is not very helpful. I also discovered the layout is incorrect as I have fuses fitted to non assigned locations and fuse not fitted in other areas. I have sent an email to Skoda (Aust) will be interesting to see their response.
    Cheers Fred
    Email to Skoda
    Dear Sir/Madam
    I was checking the fuse layout of the subject vehicle (page 196) of the owners manual, and there seems to be many discrepancies in the manual to the card layout and actual fuse block. Therefore, has Skoda (Aust) made amendments to the manual and/or the card layout. If so can Skoda (Aust) please forward the correct label for the card layout or arrange for the dealer to rectify this.
    Furthermore, I realise that some items/functions are not fitted to car and do not require fuse protection in those areas but, why are there fuses fitted to "non assigned" locations. If a fuse did blow I have know idea to the correct fuse to replace, which could be considered a hazard if head-light or parking-light failed during inclement weather of night time.
    Regards Fred
    Model: Octavia VRS Wagon (2.0lt TSI) MY13
    Dealer: Rex Corell Skoda Geelong
    Vehicle Vin: XXXXXXXXX
    Octavia Manual (page196)
    01: Diagnostic socket, engine control unit, fuel pump
    02: Control unit for ABS, ESP
    03: Airbag
    04: Heating, Air conditioning system, Reversing lights
    05: Control unit for headlamp beam adjustment
    06: Instrument cluster, Control unit for automatic gearbox, Control unit for electromechanical power steering
    07: Not assigned
    08: Not assigned
    09: Not assigned
    10: Not assigned
    11: Not assigned
    12: Central locking control unit
    13: Diagnostic socket, Light switch
    14: Control unit for automatic gearbox, Selector lever lock
    15: Vehicle voltage control unit - interior lights
    16: Climatronic
    17: Not assigned (10 amp fuse fitted)
    18: Rear window wiper
    19: Control unit for trailer detection
    20: Not assigned (10 amp fuse fitted)
    21: Cornering lights for left and right side
    22: Air blower for Climatronic
    23: Front power window
    24: Cigarette lighter
    25: Rear window heater, Auxiliary heater and ventilation
    26: Power socket in the luggage compartment
    27: Fuel pump, injection valves (diesel engine)
    28: Radio
    29: Engine control unit, Crankcase ventilation heater
    30: Control unit for automatic gearbox, Haldex
    31: Vacuum pump
    32: Rear power window
    33: Electric sliding/tilting roof
    34: Control unit for convenience functions
    35: Alarm
    36: Headlight cleaning system
    37: Heated front seats
    38: Heated rear seats
    39: Instrument cluster, windshield wiper lever and turn signal lever
    40: Air blower for heating and air conditioning
    41: Not assigned (20 amp fuse fitted)
    42: Not assigned (15 amp fuse fitted)
    43: Towing device
    44: Towing device
    45: Towing device
    46: Seat heaters
    47: Auxiliary heating and ventilation
    48: Phone
    49: Light switch
    Fuse Card Diagram on plastic cover (refer Picture 1)
    Actual fuse lay-out (refer Picture 2)
    Attached Thumbnails Attached Thumbnails Mk 2 vRS Parkers-card-layout-jpg   Mk 2 vRS Parkers-fuse-block-jpg
    Oct 2009
    Mitchelton, Qld
    So fuse #49 is for all lights.....so if some lights are working and others aren't, then it can't be a fuse, yeah?
    Feb 2014
    Geelong, Victoria
    What year is your MKII, as the manual states slot 13 = Diagnostic socket & Light switch and slot 49 = Light Switch. However, I do not have fuses in either of these slots (but every thing works correctly) so if I ever blow a fuse for the headlights, I will have to pull every fuse to find which one has blown.
    Bowral, NSW
    Have you checked the fuse box in the engine bay?
