hi all, having a weird problem and of course it happened on a weekend so no service centres open.
I can't switch between the different sections on my MFD using the control stalk (Manual vRS doesn't have steering wheel buttons). All the buttons work, ie. the rocker button and the ok/reset button does its thing when resetting the instant fuel economy for example but the long press to switch between the stereo, setup page or nav isn't registering. I have tried resetting everything by disconnecting the power for a while but to no avail (and now getting an esp error).
All fuses look fine and it was behaving perfectly yesterday. Any suggestions
the long press has always worked both stationary and on the move (although setup can't be selected on the move) as it enables you to switch between track selection, nav and normal mfd functions like ave speed, fuel consumption
but i have tried it both stationary and on the move.
ta for the reply though
Don't have a vRS but my control stalk has always gone through quirky periods where it is either reluctant to switch between readings, between screens or even on occasion scrolling through items in a different order from normal. Only does it intermittently and has never failed completely, with a bit of luck it will sort itself.
i screwed up. had the logic back to front in my head. damn shiftwork. leave this thread here as a signpost to idiots everywhere.
thanks to those that replied though
... So you fixed it? :p
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
yep, fixed the loose nut between the steering wheel and the seat. all good now
