Results 1 to 9 of 9
Thread: MFD control not working through the stalk, Manual vRS
    May 2009
    Canberra
    hi all, having a weird problem and of course it happened on a weekend so no service centres open.
    I can't switch between the different sections on my MFD using the control stalk (Manual vRS doesn't have steering wheel buttons). All the buttons work, ie. the rocker button and the ok/reset button does its thing when resetting the instant fuel economy for example but the long press to switch between the stereo, setup page or nav isn't registering. I have tried resetting everything by disconnecting the power for a while but to no avail (and now getting an esp error).
    All fuses look fine and it was behaving perfectly yesterday. Any suggestions
    Sep 2009
    Quote Originally Posted by HillbillyBob View Post
    The long press only works when the car is stationery. I assume that you are trying while the car is not moving.
    My Škoda photos here
    Flickr : Blog
    May 2009
    Canberra
    Quote Originally Posted by K1W1 View Post
    the long press has always worked both stationary and on the move (although setup can't be selected on the move) as it enables you to switch between track selection, nav and normal mfd functions like ave speed, fuel consumption
    but i have tried it both stationary and on the move.
    ta for the reply though
    Aug 2011
    Mount Waverley Victoria
    Don't have a vRS but my control stalk has always gone through quirky periods where it is either reluctant to switch between readings, between screens or even on occasion scrolling through items in a different order from normal. Only does it intermittently and has never failed completely, with a bit of luck it will sort itself.
    May 2009
    Canberra
    Quote Originally Posted by BluChris View Post
    ta, it has until monday, if it isn't working by then i will swing past the workshop and get them to take a look at it. it is the first time it has misbeahved for me
    Sep 2009
    Sorry I meant accessing set up.
    Flickr : Blog
    May 2009
    Canberra
    i screwed up. had the logic back to front in my head. damn shiftwork. leave this thread here as a signpost to idiots everywhere.
    thanks to those that replied though
    Bowral, NSW
    ... So you fixed it? :p
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    May 2009
    Canberra
    yep, fixed the loose nut between the steering wheel and the seat. all good now
