Results 1 to 10 of 17
Thread: MFD
    Oct 2009
    Mitchelton, Qld
    MFD
    Does anyone know how you set the MFD to come on to a particular display every time the car starts? For example, can you set it up so that it automatically goes to the audio display every time you turn the car on?
    My current MFD seems to have a mind of it's own and sometimes it will display the audio and other times it will display the MFD controls (like fuel consumption etc) when you start the ignition. It's becoming quite frustrating.
    Also, as an aside, does anyone know if the rear wiper on the RS wagon is automatic like the front wipers? Twice now I've seen it work (only one swipe) when the lever is not in the on position for the rear wiper, but the front wipers are working in the automatic position.
    Jun 2009
    Quote Originally Posted by donweather View Post
    Our RS always starts with whatever menu you left it on before, and in our case that's the range-to-empty screen. I find it odd that it resets itself. As for the rear wiper, I'm pretty sure it's only automatic when you're in reverse with the front wipers on (I'm pretty sure - anyone care to correct me on that?).
    Mine: Silver 2006 Volkswagen Golf Sportline 2.0FSI 6M (with a sunroof)
    Parents': Candy White 2008 Skoda Octavia RS 2.0TFSI 6M Liftback
    May 2010
    Ipswich, Queensland
    My MFD starts with the previous menu screen as per Jake's reply, but not sure how you could get it to start with anything but the MFD menu items (fuel consumption, travel time, etc).
    With auto/rain sensing wipers, and the wipers set to auto, the rear one should give one wipe when you select reverse (which is annoying when the car has been parked a while and all is dried up and the rear wiper grates across a dry dirty screen), along with the audio being automatically attenuated a bit, and the HVAC going into recirculate mode. Also the rear wiper will give an intermittent wipe while driving forward if the auto wipers are wiping continuously for a set amount of time/strokes.
    Redline3345 MY11 Octavia vRS Wagon TSI DSG | Brilliant Silver | Milltek cat back exhaust | Bilstein PSS10 | TSR Panorama | Remsa | Leather | Sunroof | Towbar | Front Sensors | Boot Protector | Xenons | Corner Fogs | Alarm | Extended Warranty | Superskoda Bits & Bling
    Bowral, NSW
    My MFD starts up in whatever you left it on... Although, it likes to go to bluetooth sometimes. (Especially if something isn't quite right in the BT connection process... signal, etc)
    When it was new, the MFD behaved very strangely. It would randomly switch to all sorts of screens. Even settings, once.
    As for rear wipers... I don't know any sort of frequency, etc... But its very handy to have that wipe every so often.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    May 2012
    Lyndhurst Victoria
    I would love to know ow to do this too.
    My RS always defaults to the Bluetooth display and all I want is the digital speedo. Also, the Nav commmands always override whatever is displaying when you input a new destination too - its already in the main display for F sake!
    Can anything be done via VAG-COM?
    *****CURRENTLY FOR SALE***** See Sale thread
    Candy White MY12.5 Octavia VRS TSI DSG wagon.
    Black Plasti Dipped wheels, grille surround, roof rails and badges. Lowered 20mm, torque arm insert.
    Dec 2012
    Sutherland Shire, Sydney
    Hmmm, some differing experiences, I wonder if firmware versions have different behaviour
    My MFD comes back on at whatever I was last viewing when I turned the car off
    When starting a navigation the MFD also switches to navigation
    My rear wiper is fully manual - has never done anything automatically
    Jan 2012
    Quote Originally Posted by Martin View Post
    the same happens with mine.
    the rear wiper setting is a VCDS tick box I believe.
    My MFD randomly goes to the phone menu when there has been a problem.
    sat nav instructions only need the 'back' button pressed to go back to where you are.
    I think when your phone connects you'll end up on the BT/Phone screen anyway.
    Jan 2012
    Earlwood, NSW
    Quote Originally Posted by Jake02 View Post
    The range to empty function is based on real time average fuel consumption as indicated by the onboard computer, so as the consumption varies the range is recalculated and updated to match. If I'm showing 130Km range left then jump onto a tollway where I'm cruising at 100 -110Kmh my average consumption is lower than in stop start traffic and the range will jump up to 150 or 160 after only a few k's. Perfectly normal.
    Jun 2009
    Quote Originally Posted by BottomScratcher View Post
    No, I don't find that the range resets itself odd (because it doesn't), I find that Donweather's MFD resetting itself is odd.
