Results 1 to 10 of 17
Thread: MDI plug location
    Jan 2012
    MDI plug location
    Hi Guys,
    I have the 3.5mm audio jack in the centre console in my MY12 vRS, however Ive purchased an ipod/iphone MDI cable. Apparently to have the 3.5mm input the car would be equipped with a 'UF6 MDI option'. Where does this MDI cable plug into? Somewhere above the glovebox or in the centre console?
    cheers!
    Jun 2009
    Northfield, Adelaide
    It's actually in the glove box - at the back on the right hand side
    Jan 2012
    Earlwood, NSW
    "Apparently to have the 3.5mm input the car would be equipped with a 'UF6 MDI option'."
    Just to clarify, the 3.5mm jack (referred to as the AUX jack), and the MDI are two different connections. You can use the AUX jack without MDI via a standard 3.5mm cable connection, but to have full device integration, and functionality via Columbus/Multi-function steering wheel you need the MDI.
    As dazag said, on later models the rectangular socket can be found mounted vertically inside the glove box on the right hand side.
    Sep 2009
    MDI is one of the biggest cons in the auto industry. VW should hang their head in shame every time they rip somebody off by selling them a MDI cable and the stupidly inflated prices they charge.
    If they weren't so arrogant rather than having their own proprietary serial interface (MDI) they would simply use USB like virtually every other auto manufacturer.
    My Škoda photos here
    Flickr : Blog
    Oct 2009
    Templestowe, VIC
    Quote Originally Posted by K1W1 View Post
    This. It really ****s me, as my car has neither MDI nor Bluetooth, and in order to add them both it will cost me around $700 if I install it myself, and then has to be coded to the damn car. Not to mention, I have to install 2 bulky modules with cabling, whereas my old $800 Pioneer AVIC that I had in my Polo had it all built in. Even $20k cars now come with both of these things as standard.
    MY11 Skoda Octavia vRS wagon 147TSI DSG
    Sep 2009
    Quote Originally Posted by tooch View Post
    $15K cars do as well.
    Flickr : Blog
    Jan 2012
    Earlwood, NSW
    Have you seen this/? BT and MDI with cable in 2012 Comfortline and above VW's. Note that the announcement was made 2 weeks after the the launch of the new Jetta. Ouch!
    To be fair, VW aren't the only one's with a proprietary interface. The MDI is definitely Apple-centric, but Apple products simply don't function via standard USB sockets. I don't profess to understand the difference, but I read somewhere that there's a difference in the plug/socket pin numbers and function allocations. Even the Apple 3.5mm jack has another tier to standard 3.5mm headphone sockets, and you can't charge via the VW AUX jack in any case. After the huge, and rapid uptake of iPods and then iPhones globally I imagine VW were under pressure to make those devices compatible with their cars. For better, or for worse, MDI was their solution. I don't mean to start an Apple bashing thread. I use Apple products, and enjoy them.
    The other options are to put music on the Columbus/RNS 510 hard drive, or play it via SD cards, which is probably what I'd do if I didn't have any Apple gear.
    ---------- Post added at 10:28 AM ---------- Previous post was at 10:06 AM ----------
    After reading my last post, don't get me wrong. I agree with your comment entirely. Mrs BS had bought me a radio for $550 fitted for my previous car about 2 years before I traded it on my RS. It had excellent BT and iPod compatability, and was more user friendly than the 9W7 I have recently imported and fitted. At least the 9W7 is much better than the "factory" option available here, which unless it's changed in the last 12 months is IMO rubbish.
    Considering what the car cost I do not feel completely at ease when I'm watching TV ads for bottom of the range Kias, Mitsubishis, and Fords all boasting Bluetooth via MFSW, and iPod connectivity standard.
    Sep 2009
    Quote Originally Posted by BottomScratcher View Post
    Somebody is telling you porkies.
    My daughters $17k Suzuki has a standard USB interface and when you plug and iPod into it you can control the iPod perfectly from the steering wheel mounted controls including having the track names scroll across the face of the head unit of the radio. Recently when I was in the USA in a hire car, a Chevy exactly the same thing happened and I'm sure anybody with a late model Holden, Ford, Toyota, Hyundai or Kia will also tell you that a standard USB does work with an iPod. All you need is an Apple cable the one that is supplied free with the device or can be purchased for $2 on the Internet if you want a spare unlike the $100 VW try to extract from suckers in Australia.
    The implementation of iPod control via the MDI is clunky at best and a disgrace to the profession of software development at worst if that's what the resources of the VW group have been able to achieve in 10 years since the iPod was released then I feel extremely sorry for them.
    Flickr : Blog
    Actually what they said was true KIWI, standard USB ports don't work, but the ones fitted in most cars also have the Apple circuitry and do both. I have plugged my Iphone directly into the Commodore one before and it just works, but in our Santa Fe, the USB port reads USB keys and other types of USB players, but to use an Apple device you have to plug another cable into that port that has the Apple circuit. The other Hyundais now have USB ports with that built in so you just use the normal iPod cable.
    As for it being standard, yes there is no reason they all can't have the port that does both, and not charge for it. It is nearly 10 yrs ago that BMW first put iPod connectivity in and charged the earth for the cables but some makers still think its a new thing. Maybe its a German thing?
    I'd also add that Bluetooth should be standard as well, I hired a cheap as Getz that had it built in and bluetooth streaming to the headunit, bit miffed that I've got essentially a top of the range Hyundai and it doesn't have that as they are using an older headunit in it.
    Jan 2012
    Earlwood, NSW
    Which is what the unit in my previous car did. I've already said I don't understand the difference, but I'm sure it's down to the head units today being "iPod compatible", and nothing to do with the cables. If you plug an iPod/iPhone into a VW USB socket you'll get an entirely different result.
    In my early days with an iPod (a mere 7 years ago) to get the iPod to play through the car stereo I had a Belkin unit with its own suitcase that transmitted a FM signal via an unused radio channel. Bloody cables everywhere, and when on a long trip I'd always have a radio station break through on what was my "unused" frequency at the time of leaving home. I'd forgotten how it used to be a relatively short time ago until I looked here. And note the 2007 prices for what weren't all that great methods of connecting.
    You certainly won't get any disagreement out of me there mate.
