Results 1 to 10 of 10
Thread: Low tyre pressure warning
    Sep 2009
    I thought this was better in another thread rather than the fuel consumption one.
    Quote Originally Posted by Tezzwokka View Post
    One other thing, my tyre pressure warning came on not long after the rain started. A check found no reduced tyre pressure. Could it be the cooling of the tyres and slight reduction in pressure due to the wet road?
    As far as I know the tyre pressure warning works by comparing the rotational speed of each wheel using the ABS sensors. The theory is that a tyre with reduced pressure will rotate at a different speed (presumably slower) than the other three. The warning will then come on.
    So as far as I can see the change in ambient temperature or road conditions is unlikely to have caused the warning as all tyres would have cooled at the same speed and maintained a speed relative to each other.
    My Škoda photos here
    Flickr : Blog
    Oct 2009
    Windsor, NSW
    My vRS has done the same thing, only once though.
    It had just stopped raining and I was cruising at 100km/h. I pulled over to check my tyres for nails and stuff, found nothing then I checked the tyre pressures, reset TPS settings and havent had a problem since.
    Seeing as the TPS works off the ABS sensors for determining individual wheel speed, I can see how a tiny amount of grit or water could foul the sensor, albeit momentarily.
    Sep 2009
    Quote Originally Posted by Calais View Post
    That makes sense to me.
    Flickr : Blog
    Nov 2009
    Maybe it was due to a momentary fouling, as it hasn't happened again. Thanks for the input.
    Apr 2010
    Melbourne, Victoria
    Mine came on a few days after I got the car, was driving on a gravel road at the time, it has been on for about 3 weeks.
    Nothing will get it to go off. Car is now at the dealers for investigation.
    A deflated tyre would have a smaller diameter (and rolling radius), it would therefore spin faster for the same ground speed (that would be the diference that the ABS sensor could detect).
    Aug 2009
    Preston, Vic
    Sometimes the TPS light will come on if the vehicle is unevenly loaded... i.e If you have heavy items on one side of the boot only as it reduces the rolling diameter of that wheel vs the other side.
    Heath Eustace... Sales Manager - Bayford Skoda Preston, Vic
    Just a big warning about the TPM. Do not under any circumstances rely on it, it's not a good way of measuring and this type (compared to what is req'd in the US) can have quite big variances before it will even go off. I had mine go off last year after about 3 mths of owning the car, stopped checked them all quickly by sight and feel to make sure none were drastically low, before going straight on to somewhere I could check them properly. 3 tyres were in vicinity of each other (36psi) but the 4th was 21psi and was the culprit. Now assuming that the dealer set it up right on pickup (somehow I think not) it had lost at least quite a bit of pressure. I should have checked them manually myself but wasn't sure how to reset the TPM so kept putting it off. But at least 8psi before it does anything seems to be quite normal with this type of monitoring.
    And no I didn't notice anything up with the steering etc, it was the passenger rear.
    The TPM will probably prevent a shredded tyre, but I don't like them getting more than 1-2psi out from each other, so make sure you all check them regularly.
    Aug 2007
    Happened on my old GTI after a new set of tyres, on the drive down to Canberra from Sydney. No real issues, and didn't have any since (even after the car was sold)
    Apr 2010
    Melbourne, Victoria
    All symptoms were put down to a faulty connector on the throttle pedal wiring, even the tyre pressure sensor which seems odd, but given the fact that it is all computer controlled not implausible.
    It's nice to be driving without a dash full of warning lights again
    Jan 2008
    Quote Originally Posted by K1W1 View Post
    If anyone is interested in how it works in detail - Volkswagen Tyre Pressure Monitoring System (TPMS)
    And a direct TPMS system to replace the indirect one - Fitting a direct Tyre Pressure Management System (TPMS)
