Results 1 to 5 of 5
Thread: Looking for Foglights for 90TSI
    Mar 2013
    Trentham Vic
    Hi there, I have decided I need some fogs for our 90TSI,
    Is there wiring in the loom to enable fogs to be fitted?
    Also anyone know where I can get a set and what part number they are as the dealers done seem to know anything about them.
    2012 Lava Blue MY12 Skoda Octavia 90TSI manual
    1978 Mercedes 300D and 1985 190E
    1978 Triumph 2500S Fireball Red
    1969 Triumph 2.5PI Mk1
    Mar 2013
    Brisbane QLD
    not sure on skoda but vw dont have any extra looms.. so if it doesnt have fog then there is nothing there... you should be able to retro fit tho.. new switch in the car wired to electrics control unit. fogs and brackets and connectors wired upto a power source and then you would also need to code in front fogs with VCDS at central electrics... wouldnt be cheap...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Bowral, NSW
    Quote Originally Posted by vdubmotorworx View Post
    Could always just use a bog standard wiring loom.
    Could even get the headlight switch with fogs and do some electrical trickery to get it to work.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Erskineville, NSW
    Do you need them because it's foggy where you live?
    I did HIDs on my main beams & find they have been the best lighting upgrade but if you need fog lights for fog then:
    Light housings are about GBP 50 / pair
    Switch is about GBP 15
    Wiring loom? Who knows? maybe BriSkoda folk have done something.
    It surprises me that the loom isn't in there already.
    You could also use a universal loom & switch but it wouldn't be nearly as tidy or integrated - About GBP 15
    Mar 2013
    Trentham Vic
    Where we live fogs are a good thing as we are at 700m ASL and the weather is already starting to get a bit misty.
    What interests me is the switch in the car has a fog setting but I am not keen to start pulling things apart on my month old car. I guess I can pull off the fog covers on the bumper and if there is a plug there we might be onto something.
    Dealers are almost helpful, i can get fogs for 120 each but wiring plugs and anything other thing, dunno but if i can get a part number they can get it apparently.
