![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
vdubmotorworx
not sure on skoda but vw dont have any extra looms.. so if it doesnt have fog then there is nothing there... you should be able to retro fit tho.. new switch in the car wired to electrics control unit. fogs and brackets and connectors wired upto a power source and then you would also need to code in front fogs with VCDS at central electrics... wouldnt be cheap...
Could always just use a bog standard wiring loom. ![Smile](https://www.vwwatercooled.com.au/forums/images/smilies/icon_smile.gif)
Could even get the headlight switch with fogs and do some electrical trickery to get it to work.
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
