Diesel combustion is quite sooty, obviously. Using premium diesels keeps injectors cleaner, maintains the power and economy and may help prevent them from failing in the Bosch systems. Ultimately it's up to you, but no way I'd skimp the few dollars difference vs the possible downside. The other option is to run normal diesel from a reputable brand ( to avoid an algae infection ) and put diesel specific cleaner through it about every 10k's. Should even out. Putting the cheapest no name diesel in your car is playing russian roulette, some good horror stories out there about that!
