Absolutely, this one works for all MQB platforms with an A5 camera.
STG 17
Long Coding
Byte 05
Bit 2 - tick
STG A5
Long Coding
Byte 01
Bit 0 - tick
STG 5F
Adaptions
Car_Function_List_BAP
traffic_sign_recognition_0x21 - set to active
Go back to adaptions listing
Car_Functions_Adaptions_Gen2
menu_display_road_sign_identification - set to active
menu_display_road_sign_identification_over_thresho ld_high - set to active
IF you get an error code due to the above do the below, if you no error when you scan, DONT
STG 13
Long coding
Byte 1
Bit 00
Now what you have to do if you get no signs picked up, I had to...
STG A5
Go to security code and enter in 20103
Adaptions
IDE04733-Road Sign Detection Fusion Mode
Change from Fusion to Road Sign Detection
That will seperate the maps from the camera and start showing signs on the dash.
In your vehicle settings under driver assistance you will see the road sign display tick box there, or it will be in the dash board selections where you turn off average speed, fuel consumption etc.
Reference: these instructions were taken off Erwin so I cannot take the credit. You'll find other instructions on the web to enable this but they have alot of other steps.. They aren't required unless you're in Europe OR you want the dash to go DONG every time you get a road sign or go overspeed.
