![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Spinifex
I always understood big brakes was better.... not only due to the increased centrifugal forces with a caliper clamping the outside of a larger disc, but the heat absorbed by the discs is distributed over a larger area for dissipation to atmosphere, hence better cool down?
Think of it this way instead, a motorbike engine heats up quickly but, when you shut it down it cools down quickly.
A truck engine heats up very slowly; but once shut down can still be warm hours later. Same principle.
EDIT: I'm not saying that bigger isn't better, but there is a point where you need to get into clever things like two-piece rotors or fancy rotor venting to get additional benefit long-term from such large units. Hence why I now run 355x32mm two-piece discs.
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
