Results 1 to 6 of 6
Thread: How to Hardwire a dashcam in Mk3 Octy, in 50 easy steps
Threaded View
  1. #6
    Pacific Paradise QLD
    Thumbs down
    Quote Originally Posted by vajnorcan View Post
    Hi, sorry to dig out the old post, I'm a noob so apologies if something does make sense.
    I've bought the 750XPlus-2CH which comes with the hardwiring cable and I've used the same fuses as you did, but of course I've used the 20A fuses for both fusetap slots and blew-up my cable's fuse (there is an inline one now). Now..
    I'd like to ask you, so if you've used the fuse slot N40, which has 20A fuse in it, did you use a fuse tap and put the original 20A fuse to the bottom circuit and **5A** to the top one? Didn't it blow ?? (the 5A one?)
    YOU shouldnt use the high amp fuses as they protect serious circuits Look in your manual and see what the fuses actually do. Stay away from ABS and Airbag fuses Find a couple of 10 amp ones and use them You only need a 5 amp fuse for the camera Its not as hard as Spinifex makes it Have done a Tiguan back and front with individual cameras and a Kamiq front camera here is the correct way to fit a Addafuse. You must fit it that way or the power goes through both if its backwards
    Attached Thumbnails Attached Thumbnails How to Hardwire a dashcam in Mk3 Octy, in 50 easy steps-wiring-addafuse-jpg   How to Hardwire a dashcam in Mk3 Octy, in 50 easy steps-addafuse-correct-jpg
