Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Help!! sudden dash warning lights..."Brakes...workshop!"
    Feb 2010
    Camden NSW
    Hey all,
    I just had this pop up this morning on the dash.
    The chimes started going off, a large red ! appeared, and the traction control / stability control lights, and the ABS lights all came up.
    They have remained on, and not reset even when the car was switched off and on several times.
    I took it to a skoda workshop at 11;30 this morning, and they were unwilling to plug it in today, and just said come back monday...oh, but dont drive it!
    Great help!
    Any ideas?
    Thanks...
    2018 Ralyee Green RS wagon. Fully optioned.
    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
    Dec 2012
    Sutherland Shire, Sydney
    Yikes, I wonder if something has taken out some wiring on one corner
    I'm assuming it's the brakes and ABS sensors (which will prevent traction / stability control from functioning)
    I could bring a notebook and VCDS cable to Stanwell Park tomorrow if you want?
    Feb 2010
    Camden NSW
    Quote Originally Posted by Martin View Post
    Hey thanks mate! I actually cant make tomorrow morning now sadly (got something urgent to do in the morning)...which is probably wise too if this has occured...Best to limit driving until it is fixed.
    I will get it checked out first thing monday morning.
    Thanks so much for the offer though!
    Jul 2010
    not good news at all.
    hope it gets sorted soon.
    and more importantly....before the skoda meet 2!!!!
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Gosford Central Coast NSW
    Lift the bonnet, check the brake fluid level. If the fluid level is OK and all the brakes still work, its probably just some sensor problem. Have a look at your brake pads.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Bowral, NSW
    Unless you want to bring them to Camden tomorrow afternoon?
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Feb 2010
    Camden NSW
    Quote Originally Posted by dArK5HaD0w View Post
    Definitley!
    I want it running perfectly for the 2nd!!
    Feb 2010
    Camden NSW
    thanks for the idea. I will look into this ASAP today.
    Sep 2009
    Check the ABS fuses.
    The good thing is that the brakes will still be working fine all that has happened is that a sensor somewhere has failed or got some dirt on it and will have most likely disabled the ABS and ESC. Driving the car will not be a problem provided you remember that you have joined the majority of vehicles on the road and have no ABS at the moment.
    My Škoda photos here
    Flickr : Blog
    Feb 2010
    Camden NSW
    Quote Originally Posted by K1W1 View Post
    Yep I will check that.
    Thanks Kiwi!
