Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Heads-up display?
  1. #21
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by zei20t View Post
    get a square of reflective tint and stick that to the windscreen where it displays. the nissans had a square built into the windscreen for this exact reason.
    Good idea - thanks
    with all your devices, i assume this uses the OBD port? that would mean you cant have it and the Polar FIS active at once?
    Indeed - and the BlueTooth OBDII unit should arrive any day as well
  2. #22
    Dec 2012
    I've now got a 360 Infinite unit - it came with a small rectangle of reflective tint, handy
    It's a much smaller, thiner and more professional unit than the hud-e
  3. #23
    Jan 2012
    picsorban
  4. #24
    Dec 2012
    Ha, I'm an IT guy and I actually had to Google that phrase
    Here you go mate:
  5. #25
    Jan 2012
    I meant in your car
    but looks small and modern. I like it!
    shame it uses the ODB port so I cant use the Polar FIS+ at the same time
  6. #26
    Jun 2011
    Quote Originally Posted by wai View Post
    I have been looking at these, and really the main thing you want is the speed reading. The problem is that with the standard speed readout being around 5% high, it kind of defeats the purpose.
    Correct me if I'm wrong but AFAIK only the VW speedo readings are skewed - OBD readings should be accurate.
    I meant in your car
    I thought Polar Fis installs behind the OBD2 port so it doesn't hog it. Would be a PITA if you needed to uninstall the Polar Fis every time you wanted to do VCDS readings...
    I tend to think all these HUD options eventually feel like a cheap and imperfect hack. Maybe in a few years they'll do it properly:
  7. #27
    Dec 2012
    I think there are two OBD speed outputs - the second one is from the GPS - no idea which these latch onto
    Polar FIS is a TEE into the gateway - to release the OBDII port you just leave the Polar FIS menu (no need to unplug) - other devices can then access the data stream
  8. #28
    Bowral, NSW
    The OBD speed readout is by the wheels, and 100% accurate... So your trip metre reads 100%.
    Speedo reading is like 7-8% out for legalities.
    Verified with Torque Pro on SGT.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  9. #29
    Sep 2009
    Quote Originally Posted by Mysticality View Post
    AFAIK the legislation is the that speedo must read within +/-5% for cars newer than about 5 years old. It used to be +/-10% but they tightened things up 5 or so years ago.
    Manufacturers always err on the side of the speedo reading slow so that there is no way anybody can sue them when they are driving at an indicated speed but still get pinged for speeding. I don't mind it makes two fifths of nothing difference to most peoples travel times and I already pay enough $140 fines to the state of Victoria for being 3 or 4km over the limit without the hassle of having to keep the needle exactly on the correct speed. 100 km at 95kph takes about 3 minutes longer to cover than 100 km at 100 kph and who travels at exactly the maximum speed without deviation that that distance anyway?
    My Škoda photos here
    Flickr : Blog
  10. #30
    Jan 2012
    Quote Originally Posted by DkN View Post
    as mentioned, it interfaces with the gateway. however, it uses the ODB 'port' to take readings for the MFD rendering the physical port unavailable.
    id have one device or the other. having to leave the polar fis menu for the HUD each time I wanted to use it defeats the purpose of having the polar fis in the first place. IMO of course
