Originally Posted by
tlli
Hi Brad,
I didn't understand why we should ride the torque curve between 2000-4000rpm (apologies, I'm not at all in tune with cars - no pun intended)?
The turbo is pumping some pressure into the cylinders from about 1800rpm & this will force the rings out onto the cylinders & help bed them in, reducing oil consumption. The 4000rpm limit was because beyond that, in normal driving conditions, she might feel like a bit of a dcik - feel free to go beyond there if the fancy takes you. No need for full throttle, just 1/3-2/3 will be fine.
