Results 1 to 10 of 17
Thread: Globe type for vrs
    Oct 2011
    Launceston, Tasmania
    Globe type for vrs
    Had my drivers side low beam headlight die today. Checked the manual is it's a h7 globe but there are different types/ brightness combinations. Can anyone assist to be more specific as I don't want two different globes installed.
    Thanks in advance
    Ben
    Ps. Would it be covered by warranty?
    Jan 2009
    Quote Originally Posted by Stealth View Post
    Thanks in advance
    Generally, the best practice is to always replace bulbs as a pair. This is done as it's likely that the other one will fail within a short distance or time, as well as avoiding different levels of light output.
    You can then store the working one in your car as a spare emergency bulb.
    Unlikely.
    Bulbs are considered consumables, which are not covered under warranty - by any vehicle manufacturer.
    Oct 2011
    Cheers for the quick reply. What bulb type would be recommended?
    Bowral, NSW
    Get a couple of 55W H7 +30% brightness bulbs.
    Typically Narva or SCA/Repco etc branded.
    They'll work great.
    I, myself, have defaulted back to my 55W H7 Narva Platinums.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Oct 2011
    Update. Had the bulb replaced at skoda today. $25 fitted same as standard. Can't beat that. Great service
    Oct 2011
    Thornbury
    Richmond charged me $75 the other day for the same thing! Thieves!!
    Bowral, NSW
    DIY: $5 for bulb from SCA.
    Getting the headlight section out is a PITA, but apart from that its all good.
    Jan 2012
    removing the headlight is hard? dude youre the light master! lol
    its easy, if it takes longer than 30 seconds, something is wrong
    Jun 2009
    melbourne
    which dealership?
    Got into the car tonight to find that BOTH my headlights weren't working
    Oct 2009
    Quote Originally Posted by 4thchicken View Post
    That sounds weird. Both going at the same time? Could be a co-incidence but I would first check fuses or relays before changing bulbs.
