Originally Posted by
Gerrycan
Anything you add to the fuel tank gets injected with the petrol directly into the cylinder (direct injection) bypassing the inlet manifold and valve stem where the carbon accumulates. All the petrol mk2 models were DI as are the mk3 except for the 1.8 and vRS which have both direct and port injection systems. The latter system has at least a chance of 'wetting' the inlet valve stem and doing something to remove the carbon build up there which is the main issue.
There are chemical (including the Subaru ) products that you spray into the inlet manifold after warming up the engine leaving it a while and then revving the loosened gunk and material through the exhaust. Worries me a bit what it would do to the catalyst on the way through
I remember GTR27 related a story where he used something similar on his totally gunked up motorbike and expelling a whole load of black soot and chemicals onto his driveway. Ran better after though.
Indeed! Nulon Foaming intake cleaner.
It was on a gsxr750 that had valves SEVERELY coked up. Basically, you do it same as subaru upper engine cleaner - run the engine, then empty half the can in squirts directly into the manifold while running, then shut off and hose the rest into the manifold. let it sit overnight, then hose them again! When mine started (after LOTS of cranking) it blew literally a cup of soot out the exhaust!
Walnut blasting of the valves is the only real sure fire way, but after that experience (and hearing others using seafoam or subaru upper engine cleaner) I think some of those items can actually help!
2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
